We just had Braid make us some new wheels for the GIO and Winfield Car.....they where about $600 a rim delivered. Pretty sure if you have the design they will remake em in stud or centrelock.
Surely a multi-piece rim is going to have a LOT more engineering and design considerations than a s1-piece, and thus cost a lot more. Pretty cool that they can do that though.
Just a quick update, the car has been at the tuners where the final mechanical touches have been done, including tomei cam gears, power steering cooler, id2000 injector plus fuel rail install, hooked up fuel surge tank plus twin 044s, installed haltech duel wideband.
All was looking good and we looked set to go testing this Sunday at Wakefield until the vipec decided to pack it in :(
It was doing all sorts of weird codes and asking to set parameters for things that don't exist on the car ie, set parameters for electronic throttle ??? You have no option but to set something, so after trying for two days to get thru to the vipec dealers ( they did not respond once) we decided to ditch the vipec and purchased a haltech platinum pro, they seem to have a good network of technical guys who will actually help you not ignore you.
Car is back on the dyno on Monday, we will post results
Looks like the car will be ready for Circuit Club on the 7th of October. If you're out there and see a very slow, blue Skyline that will be me :)
Looking forward to finally getting some time in the car and hopefully start working on those lap times.
Back on the topic of the mirrors, the GKtech's don't appear to be suitable. Should I go for genuine ganadors? Are there any other options?
Quick update.
On the dyno at Race Solutions. These guys have been fantastic to deal with:
1077184_10153307456225301_1595368808_o.j
Engine Bay with new fuel reg, fuel rail, tomei cam gears and power steering cooler. Nothing too exciting but progress all the same :)
1265378_10153307456220301_1137717677_o.j
hi im Mario from Germany this is a great build seen it when i m looking for impul rs rims becaus i m building a calsonic primera :yes: when you Need sticker decals the best way is a tamiya kit there are all sticker on it and you can let them make bigger it s 1/10
http://www.rcmart.com/tamiya-pid28351-sticker-calsonic-skyline-p-28351.html hoppe this is alowed
Edited by primera_p11
Awesome Mario thanks for posting. Looks like I have most of the decals sorted but this is a really good idea :)
Got any pics of the Primera?
Cheers!
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
