Was reading this thread many many moons ago and i remember a lot of talk about finding centre lock wheel nuts. Found this pic and although its probably not of any help you may find it interesting nonetheless.
10012987_771234859575795_168179880527460
looks like the correct way to do it to me; a rattle gun is guess and giggle torque, with a torque wrench you will get it right. Also a rattle gun is likely to push past a minor obstruction or burr which in turn makes it hell to get off again afterwards.
That center lock wheel nut is probably about 500nm
Good luck at the event, love your side pipes!
Double it.... ;)
The Sierra does up to 600nm, and the GTR was a heap more again, probably like 8-900
  • Like 1
Shit hey, I was going off what i think from memory some of the recent 911s with center lock wheel nut are using. Though I think they did a recall on them for some reason..
It's where copper anti seize comes into play! It makes for heaps more work cleaning wheels and shit for the weekend, but it makes sure that you don't have stuck nuts :D
I watched the R32 running today, looks absolutely awesome out on track. Unfortunately looks like a few mechanical issues with blow by and oil, and a few fresh water hoses needed, but I reckon you guys will be on top of them soon enough! Good work out there today!
Had great fun today, but a few issues as well. Before we took it out we has to bash the front guards to get the tyres to fit properly. Dan took it out for the first session and was having massive blow by issues. I could see huge plumes of blue smoke from the other side of the track which is never a good sign. We also managed to smash the nut holding exhaust in place so the exhaust was hanging off when it came in, along with oil pissing out of the side of the engine. Missed the next timed session to fix it so the fastest time he got on record was a 1.06, but on the qstarz he logged a 1.04.62 which is pretty damn quick I think. Best I managed was a 1.07.58 which I'm also pretty happy with.
Thanks mate. We really need to piss off all the old shitty hoses, along with the wiring. Apologies to those who got smoke screened!
Yeah I use the anti seize on all my wheel studs, spark plugs, exhaust studs etc it's good stuff
Would love to see some footage from today if there is any
I'll try and get some footage up shortly. Saw a few photographers out there, hopefully there's some good shots of it around. Looks awesome with the big wheels and tyres. Almost there!
Heya JR,
How'd the new G-sensor go?
If you want a hand band-aiding the blowby, I still have an oil/air separator to 'test' ;)
Mark :)
G-Sensor was good! Although the diffs are unloading a fair bit which is affecting the 4WD, but looks like we have fixed at least one issue. I have to say the car has never gripped up like that before, but that might be a combination of good tyres, camber and a working 4WD system. I'll give you a call about the seperator, I need all the help I can get!
Cheers guys!
10275327_10154095460620301_1803178128339
  • Like 1
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
