Calsonic R32 Gtr Replica
JimmyRickard
looks like the correct way to do it to me; a rattle gun is guess and giggle torque, with a torque wrench you will get it right. Also a rattle gun is likely to push past a minor obstruction or burr which in turn makes it hell to get off again afterwards.
That center lock wheel nut is probably about 500nm
Good luck at the event, love your side pipes!
Double it.... ;)
The Sierra does up to 600nm, and the GTR was a heap more again, probably like 8-900
  • Like 1
Shit hey, I was going off what i think from memory some of the recent 911s with center lock wheel nut are using. Though I think they did a recall on them for some reason..
It's where copper anti seize comes into play! It makes for heaps more work cleaning wheels and shit for the weekend, but it makes sure that you don't have stuck nuts :D
I watched the R32 running today, looks absolutely awesome out on track. Unfortunately looks like a few mechanical issues with blow by and oil, and a few fresh water hoses needed, but I reckon you guys will be on top of them soon enough! Good work out there today!
Had great fun today, but a few issues as well. Before we took it out we has to bash the front guards to get the tyres to fit properly. Dan took it out for the first session and was having massive blow by issues. I could see huge plumes of blue smoke from the other side of the track which is never a good sign. We also managed to smash the nut holding exhaust in place so the exhaust was hanging off when it came in, along with oil pissing out of the side of the engine. Missed the next timed session to fix it so the fastest time he got on record was a 1.06, but on the qstarz he logged a 1.04.62 which is pretty damn quick I think. Best I managed was a 1.07.58 which I'm also pretty happy with.
Thanks mate. We really need to piss off all the old shitty hoses, along with the wiring. Apologies to those who got smoke screened!
Yeah I use the anti seize on all my wheel studs, spark plugs, exhaust studs etc it's good stuff
Would love to see some footage from today if there is any
I'll try and get some footage up shortly. Saw a few photographers out there, hopefully there's some good shots of it around. Looks awesome with the big wheels and tyres. Almost there!
Heya JR,
How'd the new G-sensor go?
If you want a hand band-aiding the blowby, I still have an oil/air separator to 'test' ;)
Mark :)
G-Sensor was good! Although the diffs are unloading a fair bit which is affecting the 4WD, but looks like we have fixed at least one issue. I have to say the car has never gripped up like that before, but that might be a combination of good tyres, camber and a working 4WD system. I'll give you a call about the seperator, I need all the help I can get!
Cheers guys!
10275327_10154095460620301_1803178128339
  • Like 1
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
