  • 4 weeks later...
car looks tits dude
in regards to rebuilt motors
first rule of gtr is dont let the "nissan" out
once the nissan has been released they never last long
just ask duncan
lol best description of the issue I've ever heard.
  • 4 weeks later...
  • 1 month later...
Hi there.
32's come out looking pretty cool. Be interesting to see where the forged engine can take it. Keep up the solid work.
Also bit late new if any, regarding rims. But did you ever look at Impul R5 rims? I used to have a set on my Zed and i was super impressed with how light they were. Should never have sold them to be honest. Look like this...
Edited by Sanouske
Oh wow I thought they were called Impul RS (not R5). I had zero luck finding anything nearly as close as the rims I got and even those were difficult to source.
You definitely should've kept them!
  • 1 month later...
Update. Broke front diff on the dyno :(
We have a problem with power being delivered to the front 50:50 and cant change it no matter what we do, ie disconnect pump etc
Feels as though it is mechanically locked in 4wd, at rest when the car is on stands you can roll the rear wheels and the fronts turn is this normal?
car looks tits dude
just ask duncan
IMO, based purely on observations thats because its very hard to rebuild an engine thats as well balanced as a good stock motor out of the factory. I've been in a few stock engine GTRs and a few rebuilt motors and the 2 or 3 rebuilt ones Ive had contact with all feel like they have bad vibrations and balance purely from a mechanical point of view, nothing to do with the tune, and I say this because even when you rev the engine to say 4000rpm and kill the engine it grinds to a halt like a tractor engine. Thats purely the momentum of the parts coming to a stop.
I knew a guy that had the stock motor, his car ran smooth, did a full rebuilt for some reason or another and afterwards the engine ran very coarse coarse. I think the vibrations just cause so much more friction and stresses on components that you end up spinning a bearing or breaking a rod or scraping the cylinder wall from piston slap etc. I'd rather have a 500hp well built and tuned stock internals motor than a 700hp fully rebuilt one.
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
