I replaced my standard rear GTR diff with a Nismo 2way a while back, the best way to describe it is it makes the car a lot more predictable, it used to snap sideways when braking traction, now it just drifts perfectly. It was even more noticeable in 2wd when I broke the front diff recently.
I'm in the process of fitting a Quaife ATB diff after all of the positive reviews (like Piggaz) to the front.
Ford factory fit these on the 300hp Focus RS front wheel drive, and it got rave reviews for being able to put the power down without sledging.
Bought a Do-Luck DTMII G-Sensor unit. Should be interesting, it combines throttle input with g sensor readings to improve the Attessa.
As for the diffs, just want to test the 4wd first before thinking about changing the front diff.
Is it worth putting a quaife in the rear or is 1.5/2 way diff enough?
Anyway, now just waiting for the g sensor and wheels to arrive from Japan, then I can slap on the brakes, wheels, tyres and get her stickered up and ready to go!
In the meantime, going to pull out the shocks and suss out the suspension. Had some pretty serious understeer issues last time out.
Anyway, does anyone know where I can find these boot clips? They can be found both the Calsonic GTR and the Winfield car.
any ideas?
thanks Shaun, is there any advantage to buying the adjustable type?
Is it possible to buy these locally?
Because the latches are hard mounted it would be difficult to get the spacing between the latch and catch right so that it's neither too tight or loose when latched, having the adjustable latch would mean you can fine tune it and wouldn't have to get the spacing spot on.
Love what you're doing by the way, will be watching with interest :)
Some timing huh, I just bought my rims not long ago!
It's only a set of two though, and I would be looking long and hard to find another two to match.
Thanks for that though much appreciated! How's the Primera coming along?
got a Little time out on the Project we bought a house so i have a other things to do hope i have time for the Primera in the summer month :rolleyes:
regards Mario
Mario Mario Mario.........you know that the order of priority is GTR first everything else second!
kiddin.
Keen to see more progress of this build soon ;)
Tried fitting the C5C's. Got a few issues, one of which being the wheel nuts can't be secured as they aren't long enough. Also, not sure if they are going to fit under the guards when sitting on the ground. They have plenty of brake clearance though. Anyway, here's some photos:1896961_10153975789040301_1557877315_n.j
1536594_10153975789050301_1770344355_n.j
Anyone know where I can get super long wheel nuts?
if referring to these...
they are outside and 19mm socket too, but lock nut has got plenty of length on it. there are heaps of inside lock nuts, just need to shop around.
with wheels like that, i'd also be careful of how much thread you got available for the nuts. If not much, say hello to longer studs too. yay.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
