couple of shots from Circuit Club:
1910002_441142296025444_9137792460351887
10384909_441141792692161_482144101492869
Went for a bit of a spin!
10524630_441141746025499_784410468464564
Had a blast and Dan came third overall for the day with a 1.08!
Best I managed was 1.12 so I definitely have a long way to go with my driving, but still a PB for me. And the D2's make a HUGE difference to my confidence, damn they pull up hard.
Anyway, the old girl is off for a few more changes, should be interesting when it comes back :yes:
  • Like 2
If you're running the D2 pads (I used to distribute them) you'll find they don't last a very long time. As dar as budget set-ups go I dont think they can be beaten. Best thing you can do to them is throw a set of Project Mu HC+ at them. We found them to work incredibly well with the D2 setup. You'll never look back.
I heading to wakefield tomorrow to wake my GTR up for the first time in a few years.
Last time I was there I ran a 1:12 and that was with about 260kw and 16x8" street rubber (old potenza GIII) and full trim with stock brakes, suspension and diffs. You definately have the potential to go faster :yes:
So Im hoping to quicken that time a little now with the extra work done.
Still has stock suspension and diffs, but better brakes, semis and a little more poke.
Should be interesting :D
Booked In to Sept track day yet!?!
Not yet! Need to see if the car will be running by then!
The kit came with street pads which got promptly thrown in the bin. We ran Winmax W5 pads which were f**ken awesome for the money. Highly recommended.
  • 1 month later...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
