  • 3 months later...
  • 3 weeks later...
  • 1 month later...
@JimmyRickard i'm currently working on my Calsonic build, a facebook member sent me here and i am wondering if you could point me in the direction of where you got all the livery pieces please... although mine won't be as 100% as yours but i have a long time to invest in it
  • 1 month later...
After months of hunting down electrical gremlins the car now starts without a hitch.
Since last taking it out and breaking the hicas bar, we have replaced it with a Hicas removal kit (highly recommended over the lock bar), had a mini re-wire inside the car, installed a FullRace ETS Pro and had Heasmans give it a wheel alignment and corner weight ready for the track.
Many thanks to Myles @fluxelectronics for making sense of the many shit attempts at auto electrics from various mechanics over the years
Was great to see all the awesome cars at the GTR festival and was proud to have mine out on display for the first time. Much prefer racing it though [emoji1]
  • Like 3
  • 6 months later...
  • 4 weeks later...
  • 2 years later...
hi from Germany ... after years i look to this site im sad that you have sold the car
instate my car is ready for jtcc race :3_grin:  ... not real have 150hp ...
but it s enough for sunday cruising and the city
and my son get his own race truck with Trailer and racecar
so thanks for your Posts over the years
regards mario
  • Like 1
hi
in Germany ist not so easy to get street legal wheels in 19" for this car ....
this wheel has the closest look to the real impul wheel ...
i have also 4 original 16" impul wheels from japan in storage only for Show (not street legal in Germany)
car is stock 14t miles only race look
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
