  • 4 weeks later...
cheers mate much appreciated!
Had a great day at Wakefield yesterday, few hiccups though. Blew the intercooler pipes off in the first two sessions and the the return line off the catch can in the third, but still managed to not miss a session. Been having a look at hard pipe kits, is that the best solution for this issue?
Also, looks like we need a 1.5 way diff in the rear as the standard on is unloading and slipping, and the attessa system is doing f**k all, so i don't know where to begin with that. Would an ETS pro or midori g sensor fix the issues or would it be something mechanical? Not sure how to approach it.
anyway lots of fun, I'll get some photos and vids up shortly.
dyno sheet from race solutions. car is pulling hard and I'm really happy with it, can't recommend race solutions enough:
1497849_10153636999910301_502255709_o.jp
Heya JR,
RE: 4WD not functioning well.
Confirm your G-sensor hasn't been whacked (check bulb on unit)
Bleed the ATTESA and check fluid level in boot.
Change fluid in transfer case if it hasn't been done for a while.
If that doesn't help, let me know and we can dig deeper.
Mark :)
PS: I like the direction of your build.
Thanks for the reply Mark. The G sensor bulb is red, but i was hoping it wasn't completely rooted. I would've thought if it was stuffed it wouldn't work at all though.
Should I just replace with a digital one? They appear to be cheaper than the OEM ones.
I recently replaced all fluids in the car so that shouldn't be an issue either.
To be honest I've had this car for a few years now, and it's never felt like the front wheels were doing much of anything. It's hard to establish if the 4WD is working at it's capacity when I have nothing to benchmark against.
First of all I'd grab a mate, go for a thrash and get loose while your mate watches the "front torque" pressure gauge on the dash to see if it moves (a little or heaps. obviously the looser you get the more pressure the gauge should read)
If you're half confident with a multimeter you can check the g-sensor function yourself.
http://www.skylinesaustralia.com/forums/topic/356654-r32-gtr-g-sensor-fix/
I've never used an aftermarket g-sensor so can't comment, sorry.
My 32R gets pretty sideways before it decides to throw some power to the front, makes for a fun drive.
In saying that, if I launch it hard I'll see the gauge move every time.
Mark :)
well it doesn't necessarily mean that....the "gauge" on the outside is just an indication it has taken a big hit, not a guarantee that it is farked.
But in this case...if you have a red sensor, and if fwd doesn't work....then it might be fair to guess it is dead ;)
Try this: https://www.dropbox.com/s/8mwhmwdn3ehefdu/20131217_103417.mp4
yeah and no luck with the panasports. there's a guy in the forums who has a set of Manaray Sports which look exactly the same, but they are staggered sizes so no good for me.
still keeping an eye out though!
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
