Hi there,
I have up for sale my wife's daily drive. It is in very good condition with only 59,000km done.
This car has so many features, power and fuel economy it is truely a great packaged and an all rounder car. It is stock standard with a few added optional extras from factory. Engine is also stock and has not been modified in any way. The front lip, side skirts and rear bumper skirt is colour matched as these were just grey plastic from factory. The wife drives approx total 30min each day and refills every 3 weeks. The last time we took it on a long trip we filled up before we left and made it into Sydney (2hr drive) with the fuel guage still on full. It truely does amaze me how good this thing is on fuel and it has the power when you need it too. Comes with up to date log book service history. Last service was done recently with spark plugs and fluids changed.
Mk5 3dr GTI were made in Germany whereas the 4dr versions were made in South Africa. It is the last of this shape and is more refined. The car has been reliable and a pleasure to own.
Details and features are as below:
Volkswagon Golf GTI Mk5
2008
2.0lt 4 cylinder petrol turbo intercooled
FSI direct injected
6 speed manual
59,000km
leather interior Optional extra
individual heated leather seats (fronts) Optional extra
electric drivers seat with lumbar adjustment
metallic silver colour
dual zone climate control with dust pollen filter
bi-xenon headlights with self levelling and cleaning system Optional extra
17" Denver Alloys
5 star ancap rating
cruise control
traction control
stability control
automatic head lamps
automatic windscreen wipers
electric anti glare rear view mirror
electric windows
electric heated and adjustable mirrors
stereo and phone control on steering wheel
10 speakers system with 8 channel 250w amplifier
6 disc indash changer mp3 cd player
tyre pressure sensors
airbags driver & front passenger
airbags driver and front passenger side
airbags curtain front and rear
remote central locking
remote window open or close
engine immobiliser
alarm system with interior monitoring and tilt sensor
8.1L / 100km
ABS brakes
brake assist
EBD brake pressure distribution
automatic hazard light warning in emergency braking situation
fog lights
roof spoiler
tinted windows
anti-theft wheel nuts
colour coded lip kit
$25,500 ono will consider a swap for r34 gtt 4 door manual plus cash on top
PM or call if interested on 0411 758 793
Located in Newcastle NSW we are happy to travel to Sydney for prospective buyers.
Had a sale fall through due to the buyer not getting finance.
Happy to offer the negotiated price to anyone else interested.
Now $23000
May be interested in other swaps with cash our way. Let me know what you have.
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
