couple of things you can do really....
1) Go to Autobarn they are selling an alarm (Viper i think) which has the alarm its self and the gps unit by its self. Gps unit isnt a live feed, it works off a signal when you request it (costs $100 a year)
2) Buy a andrioid phone, put it on the simplest plan and install a tracking app. Use when required and put it in a well hidden place
https://www.sau.com.au/forums/topic/424444-gps-tracker/#findComment-6834149
Hi Mate,
We sell a few different trackers at Carbon Car System.
There are 3x I would recommend:
1. Viper SmartStart GPS Tracking - (mentioned above) - $389 inc GST + $99 Per Year
This is designed to work with a Viper alarm for the full features but you can hook it up as a passive GPS tracker so you can track your vehicle on your phone anytime. The application is quite cool you can download for free off any App Store and try it. Viper SmartStart App. This offers a real time spot location check and is really really easy to use and accurate! If you couple it with an alarm system you can get alerts on your email and phone also. It does run a cost of $99 per year but they include all the hardware, sim card in unit (telstra for best coverage) and usage of the unit.
2. Mongoose VT404 - $370 inc GST + $20 Per Year
This is again a passive GPS tracker similar to above but it is limited to its ability to SMS alerts and GPS spot location checks via SMS. It can also be hooked to a car alarm to receive alerts on the phone. Benefit is it doesn't have an ongoing cost except sim card usage so you can us a prepaid SIM costing as little as $20 per year.
3. GridTraq Executive - $499 inc GST + $20 Per Month
This is a full live tracking GPS system that allows you to monitor vehicle online through website access anytime any where with historical data stored and alerts. This is the real deal full GPS live monitoring. It does cost a little more and comes associate with a fee of $20 per month.
Anyway thats a few basic options for you if you want any help feel free to contact us anytime we are very good with vehicle security.
Kind Regards,
Daniel Gardener
Carbon Car Systems
https://www.sau.com.au/forums/topic/424444-gps-tracker/#findComment-6835140
  • 9 months later...
Any updates on recommendations for an inexpensive gps tracking device? :)
Hide a smartphone with GPS tracking app....
Seriously, all you 1 post wonders, How about using the search feature. Has been covered 11ty million times, not to mention Carbon Car giving you the answer above.....
https://www.sau.com.au/forums/topic/424444-gps-tracker/#findComment-7199574
So the smartphone would have to be on charge permanently?
https://www.sau.com.au/forums/topic/424444-gps-tracker/#findComment-7199628
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
