Hi guys, whats the deal with SAUWA? I signed up at the end of March, paid the membership fee and that's it? I was hoping to make use of the discounts with the card but havn't recieved one, I emailed and asked when it would be sent from the SAUWA "contact us" tab last week and have been ignored.... Can anyone shed some light before I start flippin tables n shit? :yucky:
https://www.sau.com.au/forums/topic/424448-sauwa/
SAUWA i found no point in joining, this forum is dead. no events, no cruises, no banter on the WA side???? whats with that?
That's all there is these days :P
Organise a social meet Damo, I'd be happy to attend :)
https://www.sau.com.au/forums/topic/424448-sauwa/#findComment-6849113
so it started as a quick cheap build right?
will whack a build thread up somewhere in the WA section so it doesnt get lost in the sea of "whats the best 5" tip for my NA R33" or who has the most hektic stagea thread.
when there is something of interest to report, ETA mid Next week on that.
https://www.sau.com.au/forums/topic/424448-sauwa/#findComment-6849232
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
    • I initially was going to do the whole car with a block then realised, it would be a bigger monster of the job 😂 I guess that's all part of the learning process. I appreciate all that advice, I think I got a good idea on how to tackle this whole job.
    • I admire your efforts with the scuff pad.  As a mere mortal, I use this for the baulk of my sanding work- https://sydneytools.com.au/product/milwaukee-m18bos125-0-18v-li-ion-cordless-125mm-5-random-orbital-sander-skin-only Yes you can easily create a low spot while sanding. There are 2 types of filler, 1 part of 2 part. The 2 part filler will get used for large corrections and the 1 part filler will get used for pin holes and areas that only need slight filling.  Depending on how zealous you are with the sander (very easy to do with a power tool) or if you are chasing rust etc, yes those low spots will need to get filled or you will end up with a very obvious defects in the paint.  Using the guide coat and large sanding block, high and low areas will be revealed (watch youtube videos for a good visual on this). Its up to you if you think its worth the effort to make the car completely flat before you spray it (you make it flat by filling the low areas).  At the end of the day, it comes down to time. The end result comes from the level of prep put in to the car. If you want a perfect result, you have to put in the time during the prep stage or else it will be impossible to achieve a perfect result during the spraying process.
