OP started this thread on 1 May ... I think this is pretty indicative that perhaps more active members should be approached and should be given a moderator status to help assist things like this (and before anyone asks - for obvious reasons, being I rarely post and prefer to read, I'm not putting my hand up)
Even the WA workshop thread, that I posted a while back and people replied with the latest info on the garages, wasn't used to update the pinned consolidated workshop thread. The WA section isn't a high traffic forum and only takes about 5 mins to read everything and respond to these sorts of queries.
Come down on July 7th... as I said we can all chat about the status of SAUWA and possible ways to help fix it's problems!
https://www.sau.com.au/forums/topic/424448-sauwa/page/4/#findComment-6910756
You gona put your hand up?
Sorry, No, as I don't hop on the forum as frequent anymore and I don't drive a Skyline so there is no urge of me to organise events if I can't participate in it.
sometimes it's better to let go and teach the younger generation how to run the WA Section so the club can move forward.
Ps. No hating on the club, it's a legit statement coming from me and a few of the old SAU members who used to hop on here and troll one another.
Edited by viet_boi
https://www.sau.com.au/forums/topic/424448-sauwa/page/4/#findComment-6911681
I used to put on cruises, however was never allowed to advertise them as "sau cruises".
I'm genuinely interested in seeing both the site, and club running back up again (as I still have a skyline). Let me know if you need mods or committee members - maybe the site does need some fresh new faces/people who are interested.. Bla bla bla
Dan - I'm still waiting for my stickers (that fit into the r34 quarter window) :P
https://www.sau.com.au/forums/topic/424448-sauwa/page/4/#findComment-6912010
Gone from one of the biggest forums to a nothing, Did we all move away from Skylines?
I still have a Few but the Import Image became very dodgy.
apart from r35s most of the skylines we own are getting old now. . people move on to newer things
https://www.sau.com.au/forums/topic/424448-sauwa/page/4/#findComment-6945716
Im glad RRP1 got his wish, yayy :) I'm glad that A cute little bbq + cruise got organised and you guys had a really good time, but.... Hmm... gee.. cough cough..... :-o If i ain't getting my membership give my $30 bucks back! Please? thank you?
  • Like 1
https://www.sau.com.au/forums/topic/424448-sauwa/page/4/#findComment-6960344
Well as Dan is clearly not watching this topic, I assume you've clicked the link in his sig and emailed him?
https://www.sau.com.au/forums/topic/424448-sauwa/page/4/#findComment-6960766
http://www.skylinesaustralia.com/forums/topic/429982-eoi-sauwa-simworld-racing-night/
4 people interested so far, one of which is an SAUNSW member and one is the event's organiser (me). Way to put your money where your mouths are WA ;)
https://www.sau.com.au/forums/topic/424448-sauwa/page/4/#findComment-6966092
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
    • And, given that you're in NC, go buy an LS7 or something equally sweet and piss that crappy old RB off. Or call up Wesley Kagan and get his help putting a Merc V12 into it.
    • Do a compression test, and a bore scope on the cylinder that lost parts of the plug. Chances are, that cylinder isn't so happy anymore...
