Hi all. I recently bought an R33 GTR making 320awkw with a power fc. The guys at the tuning shop that I usually go to suggested that I upgrade to an Adaptronic, which I did. The car is making more power now (345kw), but it takes so long for boost to come on now, especially during gear changes. Seriously, it is like somebody puts the brakes on straight after I've changed gears. The car has -7 turbos, forged internals, adjustable cams, etc. Has anybody else had this problem before? Boost came on so much faster with the power fc.
https://www.sau.com.au/forums/topic/424474-r33-gtr-re-tuned-but-now-more-laggy/
345kw from -7s probably means a happy dyno. Were both dyno runs at the same shop? Can you post the dyno readout?
What was the rationale for going to Adaptronic over PowerFC ? Seems like an odd thing to do from a bang for buck standpoint....
Can you PM the name of the shop?
The 2 readings were from different shops. My goal is to upgrade to a single turbo. The guys at the first shop told me that an ecu without afm is the way to go (to be completely honest, I'm a bit if a noob). I can't post the dyno printout, due to the tuning shop name being on there.
  • Like 1
I got my tune at the same place you got the 345kw tune (which is a highly regarded shop). FWIW i have 305kw @ 17 psi with -7s, but I asked for a safe & responsive tune (and i'm very happy with it). No-one cares about putting up dyno sheets with the shop name on them. You should ask the shop why its laggier - might be something as simple as cam timing giving you more power futher up the rev range has traded off response, or perhaps it was pinging so they backed off the timing. Also ask them if they think you have -7s (do you KNOW they are -7s or is that what a previous owner told you?).
Yeah I would say they took timing out of it so they could get more boost in and make a higher final reading (thus making you think they did an awesome job)! Depends what you asked for. If you asked them to tune for higher peak power, then they did that. If you asked them to tune for the fat power curve - they might have tuned differently.
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
