has anyone ever heard the noise that would be made from a car that is driving with virtually no automatic transmission oil? Is it a really loud churning noise?cheers
No oil = no running. Needs gearbox oil to go.
what if your driving and you have a hole in the box and its leaking and leaking, im sure itll run for a bit, i want to know for that minute or however long it will run what noise it will make. If anyone has had first hand experience with this let me know
I know that you'd be an idiot to drive with a smashed and leaking box and that it will be slipping etc etc, my question is simple, if anyone has heard that noise and can describe it to me could you please do so
cheers
No. I've tried to drive a car with little to no transmission fluid. It didn't make any funny noises or smoke, it just didn't move until I put enough in it.
If your transmission is making noise then there is definitely something wrong.
Low to no trans fluid -
It will make a grindy noise, it will feel like a slipping clutch, it will stop, it will not start if it is empty or too low. It will not change through gears.
It will NOT blow smoke.
