Yeah he showed me coz the reason I wanted to get it looked at was because my knock sensor on the dc controller was hitting 60 the other day so that's the main reason I wanted to check the tune he showed me where it was leaning out and hel fix it all up two of my other mates had a power run today and told them that there tunes were both spot on
60 knock isn't that high, RB knock sensors reads all sorts of bullshit LOL... if it's 60 on full load up a steep hill etc.. I wouldn't worry too much
What about 90 knock on full boost at about 6000rpm? Not sure why its happening, I cant find my maps on my computer to look at it now. Not sure if spend money or just pull timing my self.
That needs to be checked...
Pull timing and boost out of it
friend of mine took 3 different rb30 heads down there to get them rebuilt and prepped for an upgraded set of cams they stated and i quote
"the heads are cracked beyond repair"
at which point they refused to return them stating the damaged heads had been disposed of.
the last head that was taken to them was a known good head and the second only had minor wear if there were and cracks they could have been welded i am unsure of the condition of the first
WTF? please tell me you got something back from them?
do a map trace on the controller and see what cell it is landing on, then map that back to the ignition table.. sometimes your car loads into cells that never get loaded up on dynos..... most tuners will trim off 5 degrees on heavy load cells that are not in use just in case you hit them, but there are some tuners (1 from my experience) that disregard that and up a hill you fall into those cells and pow.. 100+ knock..
I'm going to setup my car soon and self tune it, I trust no tuner out there that would do a good tune and not rip you off. There are great tuners out there, but fuark me.. their prices are just crazy. Considering most of them just re use a map from a car with similar mods and setup the injectors & latency to suit then just spent time trimming the ignition and injection tables and make $1500 from you.
Fair enough I understand it's a business and it's intellectual property..
I just guess from 2 bad experiences with "paying" tuners to tune something I learnt myself in over a year.
+1 well said
Ive got everything I need to tune my car, its just the knowledge and the location to do it. How do you determine what is the best fuel map for your car? The timing part, I assume you'd just start low and go a little more, checking knock in each cell but its not always about raising timing until it knocks. If I knew enough, I'd tune my self but for now, its risky. I can spend my time editing the tune I have to make it a little safer, but starting from scratch is a different story for me :( Wish I had my own private track.
friend has since dropped the issue and has refused to chase advan this was his first experience with modifying a car and it has turned him sour on the whole idea
he has since slid his project into a garage and bought a commodore
Alright, everyone will have different experiences with different workshops, and hence when these kinds of threads pop up we deliberately don't let them continue.
Let me remind EVERYONE that it is against the forum rules to post negative feedback against ANY business or entity on the forums here. Threats and attempts have been made to pursue litigation against the owner of the forum for defamatory posts, and we cannot allow that to happen.
The forums are provided to you to use free of charge, but it does cost money to keep it going. A successful litigation against the owner leads to loss of funds towards running the forums. Loss of funds leads to no more forum... Geddit?
Please read THIS: http://www.skylinesaustralia.com/forums/topic/228238-read-this-whos-the-best-tunerworkshopresprayerdetaileretc/
Guest
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
    • Turn up your speakers https://youtu.be/5_GK5ChNjOs?feature=shared
