if you're looking to mac these turbos out stay as far away from the 35r as you can. Even if the 35x performance isnt as good as a 35r I would still use it.
The 35r uses a plastic bearing race as opposed to the 35x using steel.
Between a friend and i we shat something like 8/9 35r's before we got to the root of the problem.
For general street duty on moderate power and boost they are fine but if you lean on them for prolonged periods e.g. circuit work etc I wouldnt even consider one...ever
Garret were about as helpful as a front pocket in the back of my sock when we tried to get to the root of the issue.
This is one of the issues my brother has had with his 3076R setup. We're looking at more robust and cheaper options now.
We had the same issues until we got the core rebuilt by Mr Turbo on the Gold Coast. He replaces the crappy garrett guts with his and ever since we did that we havent had anymore dramas.
Its definitely a weak point with them. You really need to keep the egts low (<800c) if they are to maintain any kind of reliability in extended periods of hard, high load use otherwise the temps just fatigue the bearing cages in no time.
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
