Warmed up the R35 as normal this morning, headed off at a slow pace in manual mode changing to RRR as i go. Got around the corner and was slowing at a set of lights and like bad dream, dash lights up like a christmas tree, car switches itself to auto and i get to enjoy gears 1,3,and 5...fk! TCM warnings, contact dealer.....hmmm
https://www.sau.com.au/forums/topic/424517-another-one-bites-the-dust/
Crisis averted....reset ecu on cobb and car is driving like new!
Mods are willall mid pipe, 2012 inlets (included with the renew package) and cobb latest version running lc5....
I feel for you.. Literally
Edit: out of curiousity, what mods and LC version are you running?
Uh huh..gotta love 'em......
Electronics hey!
Hope not...going back over to willall next week so while it's there i'll get martin to take a look...
Makes you wonder if switching from LC2 to LC5 with the renew kit did anything bad to the tranny..
correct on the tranny map-can run any version of lc through to lc5. mine is an 09 running lc5....
Hey Docc, you can put any Cobb tranny map in yeah? Your car is a 2010 right?
  • 4 weeks later...
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
