I set mine up yesterday, seems I missed setting it up correctly, when the card got full it just stopped recording.
Downloading the software now to see what the vids are like after I played with some settings to see if I can get auto deletion going.
will be interested in a 2nd group buy.
so, any night vid?
or track vid?
or track at night?
i have night vids tho yet to up them, there are a few settings all seem to change the quality/outlook
Edited by Frosty
default setting is every 10mins a new file is written. Check in the software or look at the contents of card you will find files
Quality looks sweet. I'll be keen for the next group buy.
Did see a $60 special at jb's for a small similar unit. Have to see if it stacks up
Found it
http://www.jbhifionline.com.au/car-sound/car-accessories/uniden-vehicle-accident-camera-with-night-vision/684868
Can someone advise the benefits of the group buy unit over this? Keen ez
Edited by barraspalding
Read the review left on that link. Think that explains why this one is better :yes:
"Now the BAD: optics! The most important feature of any camera - quality of video recording. Picture is rich with colors, but sharpness is very low. Almost like out of focus. You can see the number plates only when right behind at the traffic lights. Up to 720p it is bearable with refresh rate (no specs on this) yet jerky with some fast movements around (turning). Above 720p is too jerky (too low refresh rate "
EDITED coz im a twit....hahaha
Edited by Frosty
Found it
sinista has covered it from the reviews on JB
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
