I'm in the process of rebuilding my 25. Just looking at my VCT oil feed, I stuck a pick into it and it only went in a max of 2mm deep. Is this normal, does the oil feed straight up into the gallery from the bottom of the block or does it 45deg into it?
Hopefully this makes sense, I want to make its not blocked because VCT wasn't working when the motor was last running.
https://www.sau.com.au/forums/topic/424564-rb25-vct-oil-feed/
Think it works as a check valve so might just be bottoming out the check valve. Just blow some air through and see if you can feel it come out. If the engine is out that is. I think if you blow air into one of the ports where the filter goes and block the other 2 head feeds with your fingers then you should feel some air come out
So I drilled feed with the top of the block facing down (I used a bit smaller than the hole size so it didn't cut any metal) and some oil dried up like jelly came out. The feed seems free now and I can get a pick in there but compressed air still doesn't come out of the feed.
I've tried blow air through various spots including both oil filter ports and the oil pump port but i get nothing from the front VCT feed!
Hi Guys,
Does anyone know where in the oil system does the VCT feed, feed oil from? i.e where does the feed tap into the rest of the system? if possible could you highlight it on a photo for me? Its hard for to now that the engine is partially built.
Yeah should be from the same feed as to the other head oil feeds.
oil pump --> Filter ---> main oil gallery ----> Head feeds
From memory anyway, I did sus it out when I had a bare block and some air and some cleaner spraying through it
can you track down a pic of the oil feed? if you can get a hold of a manual it will show it
I have the Nissan workshop manual but it doesn't detail the oil flow /path it just shows how to assemble oil pump etc.
Here's a photo of it
I got this from the oil control thread its for an RB26 though
How do you guys troubleshoot a blocked oil gallery - with drilling as a last resort as the block as it has already been cleaned and assembled...
  • 4 years later...
14 minutes ago, silencium said:
Sorry for digging up this old thread but I have kind of a similar problem.
Does anyone know if there is a check valve in the VCT oil feed or if it simply is a restrictor?
Thanks for the help
Why would there be a check valve?
How would that be useful?
Why do you think there is one?
why does it matter?
I vote my ass no check valve
That is very simple: When the engine is stopped, oil could flow back due to gravity, leaving air in the oil gallery. Next time the car gets started the air has to go out through the journal bearing before the oil follows.
I do not know how much the oil actually flows back, but it is definitely a bit, because otherwise oil pressure would be instant on the first engine cranks during start up. But it usually takes about one second till the oil pressure switch goes off.
Using a check valves in the block would make sense imho.
If one has a RB block laying around it could be checked with a thin wire.
Edited by silencium
typo
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
