hi, has anyone here had their door glass scratched by the rubber strip that runs along the outside of the top of the door? i have about four bad(wide) scratches caused by the clips and a fabric guide on the inside of the strip
what im asking what can be done to prevent the replacement glass getting scratched? i dont want to take the strip off as im sure it serves a purpose
ideas?
https://www.sau.com.au/forums/topic/424565-r32-gtgs-door-glass/
Everyone has :(
Wash and/or replace the pads on the outer door weather strip seals. Or buy a new set depending on how bad the outer strips/pads are.
Once you have done that then every now and then when you wash your Skyline clean those pads. (prevention).
NO you can not polish those scratches out (if someone says you can then ignore them).
They're white long threaded small velvety pads. You can use an adhesive to put them on (cheaper way).
or as I said above get new outer weather strips from JJR, Nissan spare parts or RHDjapan.
Caused by dust, small hard objects and in some cases broken (shatterd) glass.
To remove the strips - wind window down, un do single grub screw (under rubber near the end of the strip, door handle end) and lift from the door handles side to the mirror side. (2-3 minutes effort)...
Cheers
Richard
Edit:
Removing the door card is easy. 5 mins
-> removing the door glass is a pain, just take your time and use angles to get the glass out - Patience :)
And stick the plastic back down when your done. Prevents dust and importantly wind noise....
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
