Hi all,
I'm in the market for a second car for a little fun, and I've had my eye on a S15 for quite some time. So figured i'd put the word out there, i'm looking to buy one. (Note: I could also be keen on a 32GTR, but it'd need to be in awesome condition - Silver in colour).
I'm not looking to spend "top dollar", but i'm not going to low-ball you either. If that perfect S15 does come along, I will pay extra, but in the couple years I've had my eye on them, I've only ever seen one that was "perfect" to me, and I kick myself every day for not jumping on it.
Ideally the S15 will be in good overall condition, not looking for one with a lot of KMs, but exceptions could be made depending on how she's been treated, and rebuild history etc. Interior needs to be pristine or close. Exterior similar, I don't mind scratches or chips on replaceable parts like bumpers or bonnet, as i'd probably swap them out anyway.
As for colours, , it will vary on a car-by-car basis, depending on the wheel setup, kit, spoiler, etc. But as a general rule I like the black, white and blue S15s, aftermarket colours that will catch my attention are lambo orange, light green or MNP (something different than my plain white evo 10 ^_^ lol).
As far as mods go, I don't care - It can be stock, heavily modified, or anything in-between, the points listed above are more important to me, as i'd rather slowly build up the mods myself over time.
Best way to get in contact with me initially will be PM.
I'm located in Perth, WA.
Thanks for taking the time to read my long wanted add, as a reward for your kindness here is a cat being an asshole.
Edited by thychiz
https://www.sau.com.au/forums/topic/424586-wanted-s15-or-maybe-32gtr/
Price reflects on a car's condition in 2nd hand car market. Top dollars = top condition. Sounds like you want a top condition 32 gtr/s15 and yet not wanting to invest much. My advice is don't waste your time in cars that old if thats what your plans are. You will not find an "awesome" condition r32 gtr with 15k to even 20k. There is a genuine aus spec r32 gtr in your so called awesome condition for sale at 85k. That is with TRUE low mileage, stock, immaculate interior/exterior.
... Thanks for your input, But you have no idea of my funds or capacity to buy, I've seen individuals asking $30k from time to time for their so called "mint" S15. So that's what I meant when I said i'm not paying top dollar, I'd be more than happy to drop 20k on a nice S15, and they are widely available for this price, though not many in Perth right now (on carsales, gumtree etc) Thus being why I've posted this add. Secondly, i've noticed that the quality of cars to come out of SAU to be generally pretty good, so i'd much rather buy through here than off some shady lad on gumtree. I probably should have made this a little clearer, with regards to my intention to spend. My bad.
As for the GTR... Why would I buy an Aus spec GTR? I'm not a collector, It has no value to me outside of it's performance, and a JDM would be much more cost effective, and perform better (in most modded cases). You've taken my add a little too literally, when I say awesome condition when it comes to a 32GTR, I simply mean no dash bubble, no major rust, comp test with decent results, and just generally doesn't look like shit.
Thanks for the comment though, I'll keep what you've said in mind :)
Bump, Also just want it to be noted that I have funds SORTED. There will be no buggering around with finance etc, I have enough currently sitting in my bank for ten S15s
I've got a clean 32GTR
Listed here
Price is neg
Looks really nice, You've kept it in great condition. But not in WA (I'm hesitant to buy from out of state for several reasons, it's a lot of effort to fly to and from, i'd have to get it regod here, roughly $2k on transport, It's a lot of extra work so i'm only interested in local cars for the moment. If I start having trouble i'll expand my search to all of aus), and not silver. Thanks anyway mate.
Also here is an example of a S15 that caught my eye, if anybody in perth has something similar contact me asap :P : http://www.carsales.com.au/private/details/nissan-silvia-1999-14591654?base=1216&vertical=Car&cr=1&eapi=2&__N=1246%201252%201247%201282%204294963846%204294966407%201216&num=15&silo=Stock&sort=LastUpdate
Edited by thychiz
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
    • I was chatting with an ex SAU person who is involved in chooning euros now. He was saying the factory cars like Audi VW etc have something like 2000 tables that the ECU uses for getting everything "just right". Compare that back to any aftermarket ECU, and you'd be hard pressed to surpass 50 lookup tables. Even the Ford Barra engine has a few hundred lookup tables to run it (and they're still working some tables out too!)
    • Grab a temp probe, and probe each exhaust inlet runner with it sitting idling. Each one should be pretty darn close to the same temp. If you've got some reading higher or lower than the others, it's likely either air flow isn't equal, or your injectors aren't equal to each other.   The other things to check, is from the wiring changes that were made, were any earth's or grounds moved/changed.   Lastly, for the strut brace issue. It's not perfect, but can you get away with slipping a washer or two under the strut brace to raise it, and it still clean the bonnet? If you can, work out the height you need, that the motor can't torque up into, and get a spacer made for each side.
