  On 27/02/2014 at 12:56 AM, superben said:
Alright, I've figured it out. 3 gates -_-
I'm assuming 1 per side of the stock manifold and another gate off the turbo housing as well? haha
imagine the noise :wub:
  On 26/02/2014 at 10:09 PM, johnnilicte said:
that's horrible for flow, why not just weld a gate flange off the rear housing?
I can't figure out who to goto to get a wastegate welded on... I'd personally prefer it welded on the manifold.
Don't bother sending a manifold to me, I can't die grind the opening to the gate from the inside, and if I can't do a job properly, I won't do it at all. These 90 degree entry gate pipes welded in a hole... you are better off staying internal gate imo.
The housing on the other hand has great access. I can clean up the gate entry in no time.
Scotty do the GT Ni Resist housings weld ok ?
Also I was looking at Turbosmart 40 and 45mm external gates just to get an idea of their dimensions . What size external gates are being used on say typical RB25 GT30 setups in the 3-400 wheel wasp area .
I wish I could find the pic of a Turbosmart gate on the housing in a Skyline bay because it didn't stand out that much . I suppose real stealth would be having the gate closer to where the exhaust returns to the front pipe .
A .
It is quite hard to hide the gate, as there is no room to weld the gate underneath the turbo. You could mount it down where the dump is, but the pipe leading to the gate will be a little longer than I would like. (Plus it would need to be welded onsite)
The GT cast iron housings are very hard to cut and diegrind, but they weld fine. Stao's housings cut like butter and take half the time.
I would use 45mm for the gate, or perhaps larger. The boost control would be fine with a 40mm, but power would be more restricted. The 45mm gates are the same size Vbands as the steampipe I use so they flow nicely.
  • 4 weeks later...
  On 04/05/2013 at 11:40 AM, hypergear said:
from my testings, running the same turbo externally gated on turbine housing with stock manifold made less power then the same turbo on aftermarket manifold internally gated, and even lesser against aftermarket manifold externally gated.
Turbine housing has been untouched all times, the manifold is restrictive. So scientific solution would be attaching the external gate to the manifold. But factory manifold is twin log, do them properly requires extra work and skills, (I'm in process of building one at moment) while external gate from turbine housing makes the job easier.
Hay did end up building your manifold ?
Interested in what you came up with !
  • 4 months later...
You can't do much with it, or you will force the pulses into the other side of the log. The divider needs to stay. I would even extend it a little, to just before the gate.
I found better results by making the flow path smoother. You can't really do this running the gate off the manifold as you can't die grind it after welding.
Ok. Maybe I am spazzing out, but how late on the housing could the gate be welded on?
Now I know common sense says put it where everyone puts it, close to the inlet, but I don't want to!
I would like for ultimate stealth Ness to weld the gate pretty much at the end of the scroll, so it is directly under the turbo and hidden. (Using the stock manifold)
Is that too silly? The way I see it if the little internal gate flange can work pretty well, a less than ideal external gate would still work sort of good? I don't need to be able to run low boost
Whatcha reckon?
I reckon the further around you put it the more restrictive the whole thing will become.
Remember 2 things. There is a total amount of exhaust gas that has to flow and there are 2 holes that it needs to flow out of. If the wastegate opening is early in the flow path (ie, on the manifold, or near the inlet end of the turbine housing) then that gas that goes out the wastegate does not have to flow around the steadily decreasing area of the scroll. If you locate the wastegate a fair way around the scroll, then all the turbine gas plus all the wastegate gas have to flow that far, instead of just the turbine gas. The back pressure will climb for every extra little bit further around you put the gate.
I wouldn't do it.
  On 05/08/2014 at 5:36 AM, Kinkstaah said:
I think the issue with that (I asked Mr Scotty for the same thing) was that there's actually no room to put one there?
I could very well be dreaming, but I'm sure from underneath I can easily see the whole turbine housing. Maybe there's more room in a rwd stagea. Or maybe I am retarded.
The way I see it there isn't an ideal point to mount it on the manifold and the throat of the turbine housing is the largest area downstream of the six passages merging . Even then the mount angle sometimes isn't ideal but if you want part of the gas stream to change direction its easier to do that where the passage is larger .
For the work involved go the turbine housing or use an aftermarket manifold if you want the gate/s on it .
A .
Theres heaps of room underneath and it isn't much harder than having it higher up, mine was on a low mount 6 boost and still was enough room.
There was no boost control issue, it did seem a bit laggy though, but not sure if it was just the twin scroll ATP housing or not.
Edited by AngryRB
Do you have a pic? The 6boost manifold positions the turbo different to stock doesn't it? Sort of like an hks cast one does?
Ummm. You realise that the external gate has exhaust gasses flowing through it and is welded to either the exhaust manifold or the rear turbo housing? They withstand an incredible amount of heat. You can even get water cooled gates.
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
