Well pulling into a driveway today at an angle, i noticed that when the rear left became unweighted it free wheeled and the car struggled to get up the driveway ramp...so needs new diff by the looks of it :)
Is there anyone that has had the std Nissan diff reco'd, what can be done...who is running an aftermarket mechanical diff, names brands. I found a Kaaza dealer but its going to be about $2200 fitted for a 2-way diff
https://www.sau.com.au/forums/topic/42464-r32-gtst-diffs/
I was looking at a GTR rear cradle, friend with a 200sx was going to get the brakes whilst i got the diff. Only they need work to fit into a GTST so i didnt bother...
Id much rather a bolt in affair unless someone can point me in the direction of a mechanic that has done this modification/transplant before...as id rather not be paying for someone else to learn on my car and charge me for the process
https://www.sau.com.au/forums/topic/42464-r32-gtst-diffs/#findComment-867537
to run a gtr diff you need to put the internals inside your std casing, then run the gtr driveshafts and hubs to suit the output on the diff. the driveshafts are biggers and run bigger slpines so you need the hubs to suit, all very easy to do once you have the parts
https://www.sau.com.au/forums/topic/42464-r32-gtst-diffs/#findComment-867851
Clint to the rescue!!! So yoy sound as though you have done this?
A question no one has been able to answer for me is... is the GTR hub aluminium...im assuming the GTST is cast iron...so if the GTR is lighter, then i will go to the trouble of getting the hub/driveshafts etc, otherwise ill stick with a GTST diff.
...and mist how much are you asking?
https://www.sau.com.au/forums/topic/42464-r32-gtst-diffs/#findComment-867929
Are we talking a weight difference of 50%, 100%? Im waiting for Whitelien to release the Group 4 coilovers for the R32 GTST, if i replace the hub mount then ill be able to run R32 GTR rear shocks (available) and R33 GTST front shocks (available) so seems doable...provided the weight saaving makes it worthwhile. I suppose the added driveshaft strenght shoudl be enough to warrant the change
https://www.sau.com.au/forums/topic/42464-r32-gtst-diffs/#findComment-867981
I had my GTS25t viscous diff done by UAS for $1200 a year or two ago.
Before i had it done i would spin the wheels in the wet constantly and when accelarating through corners it would spin one wheel followed by the other and then heaps of sideways action.
Now i have to do nasty stuff to get the wheels to spin and through corners i can hold the throttle nearly flat without going sideways. Going up a gutter where one wheel is left hanging and the other planted it pulls up without ANY wheel spin. Even after a year or two (i forget how long i have had it) it will still skip the wheels ie lock up when you are turning and you apply some throttle. As far as i know it is a GTS25t diff housing with GTR internals and a clutch pack, call John Penlington and ask him since cant remember the story.
http://www.uniqueautosports.com.au/priceli...rts/r33diff.jpg
http://www.uniqueautosports.com.au/priceli...ylineclutch.htm
https://www.sau.com.au/forums/topic/42464-r32-gtst-diffs/#findComment-869163
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
