Garage clean up sale of surplus
1 S15 6 sp recon gear box 1200
2 S13/14/15 3.5" exhaust with 2 resonators 400
3 .S15 Exedy cushion button clutch fully recon push type 500
4 GTR32 left front ally guard with indicator light and badge white 250
5 GTR32 used pull type clutch excellent condition 250
6 GTR32/33 brand new Exedy OEM replacement clutch 450
7 .Apexi power FC GTR32/33 with controller 800
8 2xS15 power FC with controller 800@
9 2xGTR34 power FC with controller 800@
10 GTR34 NUR OEM Ecu 200
11 ZX300 5 sp box for SR conversion 900
12. GTR32/33 5 sp box 850
13 GTR33 S3 5 sp box 1200
14 HKS super dragger 93mm s/s exhaust GTR33/GTST 600
15 Kakimoto twin 65mm with twin rear mufflers GTR33/34 900
16 Lakimoto Titanium 75mm with s/s single rear muffler 700
17 S15 Vertex front bar 400
18 GTR34 OEM front bar 600
17 GTR34 front bar middle lip 250
17 Veilside GTT34 front bar with indicators lights 900
18 400R copy front bar with indicato rlights GTST33 400
19 GTST33 rear pods and side skirts copy unpainted 250
20 GTR33 copy rear wing with stop light 250
21 Tilton 2 paddles alloy peddle box no cylinders 300
22 Japanese bolt on 6 point roll cage with plates and high tensile bolts GTR33/GTST 900
23 Cusco front upper control arms power coated silver GTR33 300
24 GTR33 pillow ball tie rod ends new 150
25 Bride style pair bucket seats with head restrain wings and Jap seat rails Slvia/GTRs XL size new 1200
26 Nismo LMGT4 bronze 17x9.5+12 very good condition clear 6pot B-Max 355cm brakes 2400
27 Impulse 18x9.5+15 with Dunlop 280/655/18 full slicks ( one test session on tyres) 2400
28 GTR34 gold OEM wheels with Dunlop sport3000 as new tyres used for compliance and RWC only 1600
29 GTR33 OEM wheels with Falkin Azinis 255/40/17 as new tyres 1400
30 GTT34 OEM wheels with Nankang as new tyres 800
31 8 of Rays tri spokes forged 5x100 17x9 with 4 Toyo RA1 half worn tyres 1000
32 Buddy club P1 racing bronze 17x8+32 suit S15 800
33. set of Dunlop Sport King 265/35/18 street/track tyres one test session only new 535@ 1200
34. set of Yoko A050 255/40/18 half tread 400
35 GTR34 HKS twin power ignition booster new 800
36 After market LED tail lights GTR34 new 250
37 Cusco coilover S15 missing 2 helper springs 400
38 Ohlins/Mines coilovers GTR33/34 excellent for street and track 1800
will upload or send pics on request
cheers
Alex 0433878905 SE Melbourne freight at buyers expense
  • Replies 67
Is that 1200 for both seats? And when you say Bride "style", are they original, or copies trimmed in Bride material?
It is for both seats with Japanese rails to suit Silvia and GTRs. It is well made copy with Bride materials, XL size too big for me. only trial fitted
And how big are you?
Im 6'4" and weigh around 100kgs, i also have fairly broad shoulders.
Im from wollongong nsw man, so i cant come and trial fit my butt haha.
My hip width is around 43cm odd. Cant really see how wide the seat is from the photo.
Hi, Damien
Taken a better picture, around 40cm. It will be snug fit for you. check it out. It is one the the biggest size off the shelf.
cheers
Alex
GTR33 serial 3 gear box on hold
GTR33 lower lip sold ( not listed here )
Honda Civic EG composite front guards and Vented ( side and bottom) front guards on hold will upload pics
Made in Japan, brand unknown, high quality workmanship
Hi Alex,
What material is the silvia exhaust made of? is it 3.5" all the way? How did it sit under your car? Just thinking zorst clearance for getting the car on and off trailer. Was this the exhaust you had made up for Sandown/PI and the db limit?
Cheers, Alex.
Hi,Alex
This is the first steel 3.5 inch all the way big power exhaust, got over 75db limit at Sandown, put a second resonator ( cost 300, still loud) may need a mid muffler to get below 75db. sits around as my spare, tuck in very tight in S15 ( Lowered) no issue on and off trailer.
Got a titanium 3.25 from Rob,will replace decat pipe with a decent mid muffler for Sandown. S15 is still waiting for the new engine.
call/sms me for detail
cheers
Alex 0433878905 Braeside
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
