hi guys im neil and this is the story of my 2nd r34 skyline that i plan to build as a track car. DSC03692.jpg how i got it.Standard (no rego or wof, gtr rims, Cwest front kit, manual conversion) DSC03893.jpg full kit. (stolen from a friend adrians r34) DSC04274.jpgDSC04277.jpg the begining of the turbo conversion (fmic, 3inch exhaust, rb25det turbo, link g4) DSC04675.jpg conversion finished dynoed at 180kw (scraficing a diff to the drift gods on the dyno)
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/
next i had it certed, needed to tie engine loom back from rubbing on steering rack, wheel alignment and replace leaky adjustys.
the wide body kit. after seeing adrians r34 with it on i had to put the guards on mine too (with ducktape 1st)
then rivited (drift spec with crome rivits)
with pant thanks craig.(with carbon wing)
THIS IS WHERE IT WAS AT WHEN IT WAS STOLEN!
i have since gotten the shell back with a rb20de in it with my turbo etc bolted to it,painted matt black
and everything done to a prity poor standard or not finished at all.
NOW THE STORY CONTINUES...
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6839204
before
after i got it back
the car was a mess so i pulled the rb20de+t out and degressed the engine bay.
the engine after i pulled it out, sold engine for 250 and turbo for 250 yay.
the new engine, rb25de neo was a good engine last time around but this time with a much bigger turbo.
and if 370cc injectors are to small then some 800cc denso injectors might work.
starting the rebuild from the ground up i might aswell start at the back. (old sunframe)
new wc34 stagea subframe (25mm wider both sides)
have adjustable arms to go in too but will snap a pic when its all back together.
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6842802
Oh shit. Poor thing got molested :/ good to see you got it back and you're carrying on with the build mate, good stuff! :thumbsup:
+1 well done and staying motivated! Will check back for updates :yes:
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6843128
does anyone know what the rubber mounted weights are on the ends of the subframe?
they just bolted on to the stagea subframe but i thing they may get in the way of bolting in the r34
my factory subframe didnt have these (photos in previous post)
todays effort before it got tooo cold outside.
gloss black with chrome arms. (not bad)
I didnt paint diff or axles as i might go with a 5x1 diff and axles.
it goes in tomorrow.
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6846969
thanks mate i had a look under the car and was plenty of room for the weight things.
got it in and all hooked up. or asleast as far as i could, then went to help a mate gib stop his sleepout, well just watched as he worked.
next is the front subframe!
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6847856
took the front subframe apart this weekend been looking at ways to get more lock but for skylines it really comes down to knuckles and steering rack spacers.
i was going to move the steering rack forward on the subframe but been told its not really needed as the binding that is created from xtra steering lock is only an issue with silivas
and now i have a spare set of knuckles to play with and big brakes that come with em tee hehe
these will help with ajustability and they came with the set i got for rear.
i will be ditching the abs now tho because these new hubs dont have abs sensor... oh well.
Edited by sk8seddon
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6857007
well the subframe is back and its done well and reinforced to heck. dont know if its gona help or not but mite as well do it since the engine is out
now to paint it and put it together with my painted arms and tomlin knuckles te hehe
should be off axle stands saturday after craigs dyno runs....
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6875616
argh my back hard day driving forklift yesterday twisted my back.
harder day working on my car
got the subframe back in mm fits like a glove. and the steering coloum has plenty of length left for the spline to hold onto.
steering rack spacers in and loctie in place.
tomlin knuckles in place and adjustable caster arms in.
tomorrow brakes and time to roll it out of the garage and clean the garage floor.
the cr@p that falls out of these cars is amazing.
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6875619
    • Great interview on damper settings and coil selection by HPA https://www.facebook.com/HPAcademy/videos/30284693841175196/?fs=e&s=TIeQ9V&fs=e
    • Yeah, it was a pretty deep dig.
    • The values for HID colour are also defined ~ see https://www.legislation.gov.au/F2006L02732/latest/text  ~ goto section 3.9 onwards ....
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
