hi guys im neil and this is the story of my 2nd r34 skyline that i plan to build as a track car. DSC03692.jpg how i got it.Standard (no rego or wof, gtr rims, Cwest front kit, manual conversion) DSC03893.jpg full kit. (stolen from a friend adrians r34) DSC04274.jpgDSC04277.jpg the begining of the turbo conversion (fmic, 3inch exhaust, rb25det turbo, link g4) DSC04675.jpg conversion finished dynoed at 180kw (scraficing a diff to the drift gods on the dyno)
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/
next i had it certed, needed to tie engine loom back from rubbing on steering rack, wheel alignment and replace leaky adjustys.
the wide body kit. after seeing adrians r34 with it on i had to put the guards on mine too (with ducktape 1st)
then rivited (drift spec with crome rivits)
with pant thanks craig.(with carbon wing)
THIS IS WHERE IT WAS AT WHEN IT WAS STOLEN!
i have since gotten the shell back with a rb20de in it with my turbo etc bolted to it,painted matt black
and everything done to a prity poor standard or not finished at all.
NOW THE STORY CONTINUES...
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6839204
before
after i got it back
the car was a mess so i pulled the rb20de+t out and degressed the engine bay.
the engine after i pulled it out, sold engine for 250 and turbo for 250 yay.
the new engine, rb25de neo was a good engine last time around but this time with a much bigger turbo.
and if 370cc injectors are to small then some 800cc denso injectors might work.
starting the rebuild from the ground up i might aswell start at the back. (old sunframe)
new wc34 stagea subframe (25mm wider both sides)
have adjustable arms to go in too but will snap a pic when its all back together.
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6842802
Oh shit. Poor thing got molested :/ good to see you got it back and you're carrying on with the build mate, good stuff! :thumbsup:
+1 well done and staying motivated! Will check back for updates :yes:
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6843128
does anyone know what the rubber mounted weights are on the ends of the subframe?
they just bolted on to the stagea subframe but i thing they may get in the way of bolting in the r34
my factory subframe didnt have these (photos in previous post)
todays effort before it got tooo cold outside.
gloss black with chrome arms. (not bad)
I didnt paint diff or axles as i might go with a 5x1 diff and axles.
it goes in tomorrow.
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6846969
thanks mate i had a look under the car and was plenty of room for the weight things.
got it in and all hooked up. or asleast as far as i could, then went to help a mate gib stop his sleepout, well just watched as he worked.
next is the front subframe!
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6847856
took the front subframe apart this weekend been looking at ways to get more lock but for skylines it really comes down to knuckles and steering rack spacers.
i was going to move the steering rack forward on the subframe but been told its not really needed as the binding that is created from xtra steering lock is only an issue with silivas
and now i have a spare set of knuckles to play with and big brakes that come with em tee hehe
these will help with ajustability and they came with the set i got for rear.
i will be ditching the abs now tho because these new hubs dont have abs sensor... oh well.
Edited by sk8seddon
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6857007
well the subframe is back and its done well and reinforced to heck. dont know if its gona help or not but mite as well do it since the engine is out
now to paint it and put it together with my painted arms and tomlin knuckles te hehe
should be off axle stands saturday after craigs dyno runs....
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6875616
argh my back hard day driving forklift yesterday twisted my back.
harder day working on my car
got the subframe back in mm fits like a glove. and the steering coloum has plenty of length left for the spline to hold onto.
steering rack spacers in and loctie in place.
tomlin knuckles in place and adjustable caster arms in.
tomorrow brakes and time to roll it out of the garage and clean the garage floor.
the cr@p that falls out of these cars is amazing.
https://www.sau.com.au/forums/topic/424655-r34-gtt-mark-ii/#findComment-6875619
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
