Fellow members I am on the market for an 01/02 BNR34 GTR VS2.
I am willing to travel and I am a hassle free cash buyer. If anyone knows of one or thinking of selling, contact me on here or via p.m.
Requirements: Original factory black paint, no repairs, no rust, no money owed. The car can be standard or modified
Regards Neil.
https://www.sau.com.au/forums/topic/424673-wanted-r34-gtr-vs2-black/
Somebody from WA was selling a Black VS2 nur a few months ago, nice mods, I don't believe it ever sold. If it falls within your budget it is an awesome buy. His username is Huy I believe.
Thanks for reply's, I've been keeping an eye on that car. At this stage the only reason I haven't contacted Huy is "IMO" a nur should be kept standard and the k's kept off them (his words, Garage Queen), so that's why I'm after the next best thing a vs2 then I can happily mod away and put k's on it.
Huy's mods can easily be returned to standard in your case and the km's should be last of your worries. The car is in amazing condition and at least his honest with the km's. many other GTRs and rolled back and you would never know cause No ones going to admit to it.
  • 4 weeks later...
  • 4 weeks later...
At this stage the only reason I haven't contacted Huy is "IMO" a nur should be kept standard and the k's kept off them..., so that's why I'm after the next best thing a vs2 then I can happily mod away and put k's on it.
Sorry, but isn't the above a contradiction in terms?
Or perhaps you can contact Iron Chef to scout for you?
Kinda, the way I wrote it.. If I change what I'm after and decide I don't want to modify a vs2, then a nur might be a next option and leave it standard to keep its value, then Huy's would be ideal...
I have already contacted Iron Chef too.
Ta.
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
