VultureMotorsport Posted May 5, 2013 Share Posted May 5, 2013 Genuine WALBRO 255LPH External Fuel Pump GSL392 + Fittings - Very common as an R32, R33 & R34 upgrade pump - 255LPH @ 3 BAR- Genuine WALBRO – manufactured in USA with original packaging- Super compact external fuel pump (BOSCH 044 option)- Includes 2x 3/8" Fuel Barb Push-on fittings + extra 8mm union + more Key specifications Fittings In: 12mm Fittings Out: 12 x 1.5 Banjo Stub Flow Ltr/Hr (Max): 348 Flow Ltr/Hr @ 3 Bar (44psi): 270 Flow Ltr/Hr @ 5 Bar (73psi): 222 Location To Tank: 60cm Length (mm):160, Diameter (mm): 43 (Compact!) $130 incl. Delivery >> SAU Special* This is an Australian delivered product with a national warranty. Link to comment https://www.sau.com.au/forums/topic/424684-nissan-skyline-r32-r33-r34-walbro-255lph-external-fuel-pump-gsl392-fittings/ Share on other sites More sharing options...
VultureMotorsport Posted April 7, 2014 Author Share Posted April 7, 2014 Higher flowing then the old BOSCH 044 unit's >> 255LPH V 200LPH More compact and easy to fit! Link to comment https://www.sau.com.au/forums/topic/424684-nissan-skyline-r32-r33-r34-walbro-255lph-external-fuel-pump-gsl392-fittings/#findComment-7251696 Share on other sites More sharing options...
VultureMotorsport Posted April 16, 2014 Author Share Posted April 16, 2014 Now includes mounting brackets! <><><><><><><> Link to comment https://www.sau.com.au/forums/topic/424684-nissan-skyline-r32-r33-r34-walbro-255lph-external-fuel-pump-gsl392-fittings/#findComment-7259722 Share on other sites More sharing options...
beenowened Posted October 29, 2014 Share Posted October 29, 2014 Are these pumps E85 compatible or will the have a reduced life like the bosch 044 when running E85? Link to comment https://www.sau.com.au/forums/topic/424684-nissan-skyline-r32-r33-r34-walbro-255lph-external-fuel-pump-gsl392-fittings/#findComment-7416688 Share on other sites More sharing options...
VultureMotorsport Posted October 30, 2014 Author Share Posted October 30, 2014 Are these pumps E85 compatible or will the have a reduced life like the bosch 044 when running E85? Hey, Yeah they are not intended for E85 just like the 044, I would not recommend using this one with E85. The in-tank unit from Walbro is a much better option. Cheers, Brendan (VM) Link to comment https://www.sau.com.au/forums/topic/424684-nissan-skyline-r32-r33-r34-walbro-255lph-external-fuel-pump-gsl392-fittings/#findComment-7417479 Share on other sites More sharing options...
Vulture Motorsport Posted August 6, 2015 Share Posted August 6, 2015 And it's back in stock! Link to comment https://www.sau.com.au/forums/topic/424684-nissan-skyline-r32-r33-r34-walbro-255lph-external-fuel-pump-gsl392-fittings/#findComment-7582387 Share on other sites More sharing options...
