Anyone wanna help me with info on those?
Because if they are coming out with the cams to get the head off, I may as well have SOME reference. :-\
Aircon pump, bracket, bolts all in good condition, the pump works fine. $50 come get it if you want it. Give ya the condenser for 25 bux too if anyone wants it.
OK condition clutch fan.
Free to good home. LOL.
Got to here:
Before I decided I was gonna pull it all out.
LOL.
>_< D'OH!
OK guys, seeing as I've gotta rip the intake and exhaust off to do the headgasket.
Should I just convert it to a single?
Or seeing as I have the stock head gasket, etc - just chuck the twins back in?
Stay twins, and it's not hard to do in the car, but I highly suggest pulling the sump off too and checking the oil pickup isn't blocked, which means pull the engine ;)
haha, yes.. keep the engine...
Maybe the fond memories of pulling the engine out. :P
Nah gonna yank it anyway, may as well save for an engine stand, and if anyone has an engine crane, feel free to let me know.
Gonna yank the gear box and engine in one hit.
May as well do the clutch and gears at the same time.
The car has been stripped right down to the rad support to get the engine out.
I may as well just unbolt what I can of the rad support.
Gonna have fun re-aligning the front chassis if I bang the donk into it.
LOL
I wanna pull the box and engine out together, It's gonna be hell to get the bell housing bolts undone for me - so I'll drop the crossmember and lift her out.
I realised something thisarvo.
I've pulled almost everything out of the engine bay just to do a headgasket.
DERP.
So, yeah, engine will come out, and box, gonna build 'em and slot them back in.
May have to reassemble the front end a bit while the engine is out - may have to change her storage location in the next year.
Okey doke - all the Alarm systems are completely cut out of the GTR.
All the aircon system is out bar the main cables and heater bar setup.
Pulled everything away from the front of the car so the engine and 'box can be slid forwards to split them.
Just have to disconnect all hoses, plugs etc to be able to yank the donk out.
Gonna need help to put it all back together eventually though.
Anyway.
2 AM, and I need sleepz.
Everything is coming out of the engine bay for a clean and replacement if necessary.
If I wanted to JUST do the head gasket, I would have paid to have it done.
Everything is being stripped back to the metal, I wanna make it all clean, reroute a few things, etc.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
