Has anyone had a problem with nitrogen leaking or anything I had mine done a month ago and I had a warning light come up so I've had them filled again and it hasn't even been a week and my lights come on again. What do you's think it would be? I hope it's not the tyres they are pretty much new not even 5000kms on them
https://www.sau.com.au/forums/topic/424693-nitrogen-leaking-from-tyres/
If it's one tyre, a nail or something.
If all tyres are doing it....average temp drop due to winter?, as even nitrogen expands and contracts too due to temperature, just not as much as the usual plain 'air'.
It will be a slow leak. I had the same problem with one of my tyres. If you have runflats it will usually mean a whole new tyre depending on the where the damage is and if the tyre place will be willing to repair it.
Jason, that sounds strange.. What pressures are you running them Cold ? I run mine around 32PSI cold, and i have noticed all the tyres have lost approximately 1psi over the past 7 weeks. (Could be colder climate).. But to lose pressures to the point of Low Pressure on the Dash indicator after a week doesnt sound right, Have you manually checked the tyre pressures to see if the Pressure Monitoring system was right there is a low pressure problem ? If tyre pressures checked via Gauge is OK, you may need the TPMS sensors reset, which i believe is a something you need the Dealer to do ..
I'm going to get it checked tomorrow and when I got my first warning light on I checked had all the tyres checked and most were around 29 and 28 then one of them we 26 and they were pumped to 32psi... I recently had them set to 31 just last week so it will be interesting to see if its the same tyre which was low last time... Also lets say it was a tyre that's damaged am I better off replacing the 2 or just the one?
Jason, unless the tyres are very new, you should always replace Tyres in pairs (Ie: Front Pair or Rear Pair ).. If you dont , you may end up with different grip profiles with a new and worn tyre from left to right, and you also have differing rolling circumferences which may put further strain on the Diffs.
But you should get the Dealer to really check whats going on with the Tyre thats going down before making any changes.. (It could be as simple as a faulty valve)
Yeah I thought so it says in the manual to replace all 4 if any are damaged for even wear I just bought 2 rears and it cost me $1260 delivered to my door not bad but pretty dear for the damage of one screw :(
Nah I have the bridgestones on mine and I looked at getting the dunlops but old mate says they are heaps dearer and thought I may as well stick to the same brand I ordered them from Tempe Tyres the other place quoted me just under $900 each so about $1700 for the pair so I'm saving at least $500. Next time I need tyres I will probably get a full set of the new bridgestones the R2's
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
