Hey guys,
I'm about to get some intercooler piping made up for my r33 rb25det and just want to confirm some things.
Because I have fitted a forward facing plenum and new turbo I'm planning on shifting the afm to the piping ( throttle body side) and will also have on that same piping from the intercooler to the throttle body the BOV, spot for water meth injection and a spot for the ACC valve from the plenum. Things will be tight so not sure as yet if the AFM will definitely be relocated but that's the plan. However I need to confirm what order these 4 things go in and the spacing. At the moment I think it would go in this order (being closest to throttle body first and close the intercooler last): water meth (80mm from TB), ACC (100mm from TB), BOV (200-300mm from TB), AFM (close to intercooler as possible).
If this is not correct please let me know. Any help is much appreciated.
Cheers
That would not be correct. You would want the AFM to be downstream of the BOV. Otherwise, with the arrangement you've listed, your AFM will register the flow of air through the BOV as the turbo-intercooler volume vents through the AFM towards the BOV (and then probably measure it again as it goes around again, and maybe again!).
I hope you've got a programmable ECU or it's going to be a world of pain with the AFM in the pipework otherwise.
That makes sense that the AFM should be on the throttle body side of the BOV adaptor..
Yeah I have a PFC. Doesn't make a difference if the BOV was plumb back or athmospheric does it?
So the original way is correct if its to atmo? Being BOV throttle body side of AFM?
Air that is lost to atmo that has been measured by the afm already can be tuned to compensate?
No, when I said "the above arrangement", I meant the arrangement immediately above, not the arrangement most above. That's a standard form for referencing such things.
To specifically answer your question, you do not want to vent any air, ever, that has passed through the AFM to any other position than downstream of the AFM. To phrase that another way, if the BOV is downstream the AFM, then the return must also be downstream the AFM. If you vent it out to atmosphere after the AFM, the ECU sees it as air that needs fuel and you get rich shenanigans.
intercooler > afm > bov (vent to atmo or turbo intake) > WMI > throttle body
I dont think it will matter so much with the afm that close to the throttle body cause it will re-read any incoming air...there is not enough caught up in intake piping between AFM and TB to make a difference..its probably easier to just have an atmo bov...
not sure i liek the idea of the WMI and AFM being so close together though...any reason you cant leave the AFM in fornt of the turbo?
Just want the Afm in the piping so I don't have to put a restrictor on the turbo intake. Even though it would effect it bugger all I think it'd look a little clear being the same size all the way to the filter.
Would it be easiest to just have the AFM throttle body side of cooler and have BOV turbo side and vent it back to intake piping?
Has anyone placed the BOV turbo side? I figure it would be ok if it was venting atmo cause it would be disposing hot air and if it were plumb back would be better on the cold side to recirculate the cold air back
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
