Hi guys,
As gay as it sounds, I need to turn the boost down on my R33 GTR. Its my first GTR and im still getting to know all the biz about them. It's hitting 17psi and running the standard turbos. Surely this can't be good! Basic run down of mods are power fc, air filters, full exhaust (standard dump pipes) and from what I believe, the 'free boost upgrade'. I had a look on the boost solenoid and the is no yellow line on the black hose which leads me to believe the hose has been changed? What would be the easiest way to bring the boost down? I was thinking of putting in a bleed valve to get me by or even put in a ebc (which i prefer). I plan on changing the turbos down the track but have other priorities right now and will have to wait a bit hence why I want it to last a bit.
Your help is greatly appreciated.
Thanks,
George
https://www.sau.com.au/forums/topic/424751-help-me-bring-my-boost-down/
clearly there is already a bleed valve or ebc to get it to 17psi and tune to suit. im guessing you have just bought a car without knowing what aftermarket parts controls its boost??? maybe the power fc ebc kit. remove the vac line from the controller and plumb them straight to the wastegate, if you lower your boost a lot you will run quite rich when the tune expects 17psi and gets 10psi
Edited by Jayden.K
Thanks for the info. Yes, i have just bought the car a few weeks ago. It definitely looks as if there is no boost controller of any kind. Still retains all the factory lines from the actuators etc to the factory boost solenoid. When you say remove the line from the controller and plumb it to the actuators, are you referring to the 2 boost solenoid hoses? ie. join them together?
Thanks
George
ok. decided to go out in this cold melbourne weather and have a look around. there is no aftermarket boost control kit or pfc ebc kit. what i did find was interesting though. i pulled off one of the lines found a bolt in one and thought...oh no...and on closer inspection, there was some holes in the actuator line. i pulled the other one off aswell and that was blocked off too. i pulled the bolts out and have connected them to the solenoid so it works as it should. It now runs 12psi @ WOT which im much happier with. it boosts much better, comes on boost quicker and drives better. its a tad slower as the boost has dropped, but i think this is better. attached are some pics. if you have any other ideas on what i could do, please tell me! haha.
that is some crazy dodgy work lol. now that the boost is lower it wont feel very quick puling from 5 to 8 grand. plus it maybe running rich now which will bog it down, so when it use to see over 12psi it will add fuel to compensate (aka thats it tuned) now the airflow isnt there, its just waking fuel in for 17psi of boost when there is only 12. fact is if you have a pfc, you must get it tuned when you change things like this
Edited by Jayden.K
also sense you have a hole in your vac line. it will pay to get your boost leaks check. it will run so much better if you fix any. do this before you tune again. otherwise it will run lean if tuned with leaks, then you decide to fix them
Jayden.K - Thanks heaps for your input. I wasn't too sure if the air/maps are locked in the PFC which sounds like it is. I've just been cruising it and not taking it past 5k as it doesn't really have much pull from there onwards. It sort of flat spots. It definitely runs better they way it is set up now and i have replaced that hose with the holes in it and have gone over the vac lines and have not found any vacuum leaks. Looks like im going to book it in for a tune really soon then :)
to easy mate, btw vac leaks and boost leaks are 2 different things but if you have a leak at vac you will with pressure. you will need a pressure tester to put into your intake, force air in and when you close the valve you will hear air coming out in all sorts of places, i had no leaks at 5 psi but then leaks at 20psi. things like hose clamps/ split hoses, gaskets etc. then after there fix, it will pay to check it every 6 months or whatever. ask your tuner if they can perform this, if they dont no what your on about get another tuner.
maps are locked, unless at hot idle or cruising then it switches to closed loop and reads the o2 to calculate a/f ratio.
its really shit because if the car knocks, it doesn't retard timing. it just follows the map!!! something that comes in handy on steep inclines, burnouts and hot days which shoot knock readings up from engine load. not sure if other ecus do it like vipec/haltec, motec, wolf v2, nistune piggy back blah blah
Edited by Jayden.K
  • Like 1
What?
Dropping the boost won't make it run rich. if it is tuned for 17, it can obviously run 12, because it would have been with part throttle. The afm will read the airflow and add the correct amount of fuel, less boost, less afm voltage, less fuel.
What?
I agree, ECU will adjust fuel depending on load (AFM voltage) Regardless of PSI. Would be different had the boost been raised above 17..
Wow. More info. I knew with the standard ECU they self-adjusted, just wasn't too sure with a Power FC (never owned a car with aftermarket computer before so its all new to me!)
From what i have read, running the way i have it now, a lot of people get 1bar (14psi) boost. Why would i only be getting 12psi? It also doesn't feel like it pulls from 5k-8k the way it use to. Can anyone shed some light on this? Should i disconnect the battery to reset the computer?
Thanks,
George
What?
I concur with the concurring. Jayden no correct.
sorry, i thought that was how it worked with power fc.
Edited by Jayden.K
Yuh, PowerFC same as Nissan ECU. Measures load with AFM, so it's not tuned "for a boost level" so much as it is tuned quite naturally according to the amount of air going in. Less boost = less air = just running from a lower load part of the fuel and timing maps, exactly as if you were using part throttle.
When I say "not tuned for a boost level".....that's not entirely true, but it's close enough. Obviously if you have more boost you end up needing maybe richer mixtures and more conservative timing. But it's not really possible to separate these effects for a given turbo+ECU+AFM+engine combination....so the tune is effectively not dependent on boost as much as it is on raw measured airflow. For that given combo, less air must mean less boost, whether that airflow/boost is turned down by throttle or by boost controller doesn't make much difference.
If you increase boost above what it was tuned at, you will go off the end of the old tune and out into unexplored territory and you might blow it up (lean mixtures or too much timing the main thing here).
yep cool, i just thought powerfc were really basic computers and once it set thats it, guess i learn to never assume anything. sorry about the incorrect information
you've all been very helpful with the problems i've experienced.
But can any one shed some light on what i posted earlier?
see below.
thanks
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
