revolution race gear?
I forgot about it so will probably make one with electrical tape.
weather forecast is improving.
I'm in the same group as Ferrari 308 and the X3 :/
I picked up some rolls of blue and red contact (the stuff I used to cover my school textbooks with to protect them) from the local newsagent
Just a couple of bucks and cut a triangle out with scissors for battery and tow indicators
KB most likely, as they have to submit the lists to the timing people and CAMS with enough time for all of the checks and data entry to be done.
1 lap before the motor carked it was a 1:29.7 i think. Was running on low boost, and shifting early all day to keep in the torque range... might have accidently over-revved it once, hope that wasn't it. Temps were great all day, suffered a little bit from oil burning when braking.
I've never been much of a fan for the 35R's but the two out there on Saturday sounded fantastic with speed to match. Artz said he may have got some video footage.
Some footage of me trying to keep up with NEIL00 :(
Great battle with Neil, spose him and his cheater 340kws is a bit unfair but you pull him right up on the corners!
Had a great day thanks to everyone there...
http://youtu.be/GxnuZiqHgsM
Great time! Interesting to see the top speed a stock 35R reaches at Sandown
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
