You might know a guy do you have to pay for pit garages there? And spectators
Paul I also have some oil for you
Yeah have to pay - $40 I think, good to have given the weather outlook. I have the guys number ill send it to you on fb.
Haha don't worry about the oil - I have it coming out my ears. I had completely forgot about it.
So the Collins Class is all ready for the big Sandown debut? (I just thought of it - I had to use it :P)
Guest
