Ok i installed some GTR camshafts in my RB20 today. also fitted a new timing belt.
so here are my probs.
when i installed the cams i noticed the inlet cam was much harder to turn than the exhaust cam when making small adjustments to align the cam gear marks for no.1 TDC
after thinking maybe the new cam was bent i pulled it and installed the standard cam, but it felt just as stiff to adjust, so back in went the GTR cam.
Now my problem is the car cannot hold idle without droping rpm and then dies
now when i try to start the car it pretty much dies immediately.
is this due to the "lumpy" camshaft or something else?
any advice or help would be much appreciated.
Ben.
https://www.sau.com.au/forums/topic/42478-camshaft-instalation-probs-help/
  • Replies 88
A bit of a stupid question (I'm not sure how the cam is mounted etc..), but did you put the cam mounts/craddles back in the same position??
I replaced a cam on an old car years ago and it did the same thing, found out that the mounts/craddles that hold the cam in place were put on in the wrong order (my bad !!) which put a fair bit of load on the motor cause they were slightly out of wack.... I ended up needing to get them line bored to fix it...
Not sure if this is your problem, maybe someone else can confirm.
J
I would say, if your belt is on right, marks match up, all hoses back in the right spot (eg. Crank Reciculation Thingi) and CAS on the right mark(by eye), reset the ecu and try starting it and holding the idle up for a couple of mins and see if it help but other than that i'm stumped.
dunno if that is any good tho
yeah i have tried everything everyone has mentioned here.
the only thing i think could be causing it is the fact the inlet cam felt much stiffer to adjust than the exhaust. it was noticably harder to adjust, i think the engine is having trouble turning it over at idle and hence stalling.
the only thing is, when i noticed this problem when fitting the GTR cam i decided to throw the standard item back in position to check there was nothing wrong with the GTR cam. But the standard one felt just as stiff...
i dont think i dropped anything in, i was pretty meticulous doing this job.
there are no strange noises to suggest there is a spanner in the works (literally).
I only can think of a few things that are causing this.
- either the fact the in.cam was difficult to turn is causing the problem.
- the timing belt has jumped a tooth or so on start up (i doubt this)
Considering they are a very mild cam upgrade compared to the standard items the ECU should be able to handle them.
so im stumped here.
i think ill pull the whole lot out and go back the the drawing board.
Hi bbenny, check the clearances (feeler gauges) between the cam lobes and the buckets, if there is a bent valve you should see large clearances that the hydraulics can't take up. If it is not missing, then I doubt this is an issue.
You really need a timing light to confirm the ignition timing. Have you tried advancing the CAS and seeing what effect it has on the idle? We usually have to run a bit more advanced igntion timing at low rpm with aftermarket cams.
hey sydneykid
i invested in a timing lamp today, i did adjust the CAS and it was a little better when advanced but still wouldnt hold idle
it doesnt backfire or sound bad at all, when i drove the car around the block (taking it easy) it was extremely sluggish, i found that response was really poor at low rpm, even if i fully opened the throttle nothing would happen for some time till it reached 3000rpm but even after that point it was very slow.
ylwgtr: i dont think ihave bent any valves because at no time did i rotate any of the cam shafts - i only noticed the stiffness of the in. cam when making a minor adjustment to align the pully marks.
thanks for all the advice here guys, keep it comming, i will begin to pull it all apart again tonight and try see if i have missed anything. if it still doesnt work after rebuild no.2 i will throw the standard cams back in and see if i still have the problem.
sydneykid: did all your installations have good idle or did you have similar problems??
Hi Benny,
I just finished my cam swap as well this past week and the car has been down since with the exact same problem you are describing.
The timing marks are dead on, all 6 plugs are getting spark, and there's PLENTY of fuel, I know this because the plugs almost instantly foul after a couple attempts at idle. I have noticed that when it is colder outside the car will idle until it warms up a bit, my ECU is now pointing the finger at the coolant temp sensor. I have also performed a comp check of all 6 cylinders and they all read the same value, I am under the assumption that if there are bent valves then the comp gauge should not hold pressure (I could be wrong, it's happened before). Of course if I have valves bent in one cylinder then somehow I have valves bent in all six and I think I would've noticed something, a noise perhaps. I have checked everything I can think of at this point and have been using my wife's S14 as a taxi lately. I have ohmed out the harnesses to the AFM, swapped AFM's, CAS's, and ignitors with a friend's known good parts.
But I am so glad someone else has performed this swap and seen the exact same problem as I have. You are not alone...
I'm going to replace my coolant temp sensor tonight after work and see if it makes it better, my car has idled exactly 3 times since the swap and everytime its been after it was a chilly rainy evening.
I'll re-post after I check out this temp sensor issue, hopefully with some positive results.
Of course any other ideas/suggestions are appreciated :rofl:
-Matt
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
