  • Replies 88
god i hope you guys sort this out eh...... i was gonna buy an rb26 for my gtst but ive decided to do the gtr camshaft swap cause the rb20 in my car is running fine and ive just spent over 3k on a turbo setup so should try and develop it a but more before i pull it out.... i also have microtech so i can adjust my ratios/timing if needed..... im keen to see how you guys go... good luck.....
and just a tip.... my mate broke his tensioner bolt on his rb20 after doing had timing belt... only problem was it happened at about 5000rpm as he diddnt realise he had over tightened it.... and the end result?? 22 bent valves so just be carefull and take ya time eh :)
I managed to throw the engine back together this morning and had just enough time before work to do some SAFC tweaks. After leaning it at low RPM quite a bit it has better, smoother throttle response. I still can't get it to idle above a couple hundred rpm. I need to find a way to get the idle speed up on the stupid thing, if I could manage to get to about 950 or so RPM I would be home free I think.
Can you tweak the idle settings with the ignition on without having the car idling already?
Thanks,
-Matt
good stuff Mabru! is it holding idle at all? or still stalling after a bit of effort.
have you taken it for much of a drive?
let me know when you have time.
i decided to get my rocker covers sprayed while its all apart. last night i managed to tear my finger right open and rip the nail off, so my poor little finger needs a break. so i wont have it back together till wed i think...
Nah Benny, same stuff so far, idles really really low then croaks.
I am going to try and adjust the idle speed a bit when I get some more time to look at it and tweak the low settings a bit. Once in a while it will idle, but it's not very common yet. I'll work it out but it takes time I guess. I promised a friend I'd do his auto-manual conversion tomorrow so there goes a chunk of my troubleshooting time!
-Matt
I did try it at first, but this whole cam issue has forced me to track down a couple problems that were pre-existing so I've gotten sidetracked a bit. The AFM plug was having intermittent contact and the water temp sensor was stuffed.
I've taken care of these two issues and now I can back on track again, I'm going to try and adjust the AAC after work this evening. As I posted earlier, leaning out the SAFC on the low RPM/low throttle made the car feel better but the idle was really really weak, to the point it would stumble and die off after a few minutes.
I'll give the AAC another go and see if I can coax it up a bit.
-Matt
WazR32GTSt
The reason it wont lean out is because the air passing through the AAC valve is still metered by the AFM. Thus the ECU injects the amount of fuel that corresponds to the AFM reading and so the A:F ratio should stay the same.
If you were to pull a vacuum hose off so the engine was sucking unmetered air it would get lean.
I think i might give up on the idea.
From what Sydney kid says, its a great upgrade with awesome results if you have an aftermarket computer to tune according the the cam change. However as i didnt have a new computer in my budget i think im going to pull the cams and just go adj pulleys.
I would love to keep them and have an average 25rwkw power upgrade, but unfortunately i dont think its gonna happen with a standard ECU.
So anyone out there with aftermarket management, mine are for sale $280 to who ever wants them. I paid $350 for them from T88 onboard, they have only done 30,000km.
Everyone else who is doing them, let me know how its going.
Ben.
The RB20 is an interference motor.. Ask Bl4ck32 all about that when his idler bolt snapped after the mechanic tensioned it too much. :)
I've had the same issue with the timing light, timing jumps about and is way way off the scale.
I put it down to a cheapish light. I also read some where a while back that you need a certian spec light. It may have been in the R32 Engine manual.
Yeah Bbenny,
I've given up for now as well, no amount of SAFC tweaking gave me an idle above stalling. I've already got the RB20 cams bolted back in now, I'll finish up in the morning and hopefully be none worse for wear. I'm sick of my car doing it's imitation of a statue!
I'm thinking that the 4 degree retard on the exhaust cam that SK recommended would make a hell of a difference.
-Matt
    • The SS button head cap screw on the back? If so, good to know. I presumed it was there for basic assembly and nothing more.
    • Hello, everyone. I'm new to the forum. I have a 1989 Nissan Skyline R32 GTR. I have lost all power to the interior, including AC controls, the gauge cluster, turn signals, and windows. Stuff that still works includes the horn, brake lights, radio, and headlights. All fuses, in the interior and exterior boxes, tested good.  It starts and runs fine, just with no gauge power or anything stated above. No warning lights either. Things that I have tested: - Fusable link tested fine - No other fuses blown - Alternator good - IGN switch tested fine - With my power probe, I can backfeed power through the IGN pin to the plug on the back of the gauge cluster, and everything comes back on.    So my theory is something on the control side that sends the ignition power through the system isn't doing its job, or a wire is broken. (I would think that it is the ignition switch that would do that, but who knows?). The ignition relays don't fire (all relays tested good). So what tells them to fire other than the IGN switch?  I would really appreciate it if someone had some insight on this. I have tons of hours into this; I don't want to give up in defeat! I have the HD wiring diagram, but having all those wires laid out like that on one sheet of paper makes things pretty hard to follow.  Thanks for reading, and thanks for the replies.  Where should I look next? Thanks.
    • Install a MAP sensor pre and post throttle. Best data you could have for NA, then play with the bends and/or air box and see how much of inflection is created at WOT on the plot.
    • And gone to a new home
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
