I have a set of four HSD coilovers.
In very good condition. Adjustable bump/rebound and height.
Perfect for street or track.
Not 100% on spring rates but think around 7-8kgF/5-6kgR.
Came out of R33 race car but I think will also fit R34.
Looking for $600 inc free delivery Aus Wide.
post-53650-0-38385200-1367889290_thumb.jpgpost-53650-0-68209400-1367889296_thumb.jpgpost-53650-0-03121700-1367889302_thumb.jpgpost-53650-0-85041600-1367889307_thumb.jpg
https://www.sau.com.au/forums/topic/424786-hsd-coilovers-r33r34/
R34GT should have the eyelet type, same as R33 :)
R34GTT use a fork type on the rear!
Cheap coilovers, good deal! Good luck!
Could you wind them as low as they can go and measure from the top to the bottom and get back to me? Its just I put gtst coilovers in my gts4 and they couldn't go low enough but these look like they could get a fair bit lower
OK measured.
The front when lowered are 430mm from the top of the hat to the middle of the mounting eye.
The rears are 600mm from the hat to the eye.
You would also be able to move the spring perch down to gain some more but I didn't do that for this measurement.
I need some fresh coilovers for my car. Are these comfortable? Ive got teins on my car and they are hard as shit and uncomfortable to drive on.
Hard to say as everyone has different opinions on hard. I never foundnthem uncomfortable.
    • does anyone know tie rod torque setting and anti roll bar for r34? Is there a workshop which shows various components torque setting?
    • Hi    have purchased pair of eibach wheel spacer as I couldn’t fit set of wheels I bought for my car due to it catching caliper.   I know I need to cut the bolts on my discs so they sit flush with the nut supplied but the nut doesn’t sit all the way into the groove meaning wheel would not directly fit onto the spacer rather the nuts. Any thoughts?   See pic   https://ibb.co/VJK5w5G
    • Nah. There's not shit tonnes of pressure in there. Just drill with a 1.5mm drill or something equally tiny. When the drill goes all the way through thee gas will start to come out, but with such tiny path through the flutes of the drill bit, it won't be at all dangerous. You can be as paranoid as you like from then on. I'd just pull the drill out while keeping my face out of the line of fire. But then, I spend half my time looking into pressurised furnaces. So my risk acceptance is somewhat higher than most!
    • Been needing a new clutch for a while, but holding off because of life tingz and adulting. But... Being of Asian descent, I can't pass on a good sale, especially everyone else is selling it for $2k+ (JJR has it for $1799). Really on the fence on this one, because the unsprung version of this is $1281 via Shitbox (Sparesbox) and the sprung version is quite a bit more (no idea why Shitbox doesn't offer them). Ending up just sending it and getting the twin sprung organic. Mainly because I wanted the car to be nice to drive and didn't want to make it more of a shitbox than it already is.
    • It was the pressure I was worried about. @GTSBoy does drilling them pose any problems?
