I inhiereted a mls head gasket.It is a 5 layer one.my question is do these mls gaskets come in different thicknesses ,are they reusable and because my head has been skimmed is it gonna stuff around with my compression ratios.is there a way to work it out or is a standard head gasket just as good.im going for forged pistons as I have to rebore slightly due to a bit of cylinder damage anyway.cheers
https://www.sau.com.au/forums/topic/424799-head-gasket/
Yes they come in different thicknesses.
No MLS gaskets are not reusable as they normally have a coating which bonds to the mating surfaces. If you have assembled a motor (not run it) and pulled it apart again you can usually reuse the MLS.
Yes skimming your head will raise your compression ratio. If the gasket is thinner than stock this will also raise it further. Generally skimming alone wont be enough to warrant a tune or any serious change.
If you are building the whole motor you should buy a proper gasket and not use a second hand item. Know what is going into the motor and don't waste your efforts on second hand consumables.
https://www.sau.com.au/forums/topic/424799-head-gasket/#findComment-6841790
I think I might just go the standard nissan.as there are very very slight machine marks in the head surface that might not seal properly with a mls.standard headgsakets are ok for moderate power increases aren't they.
https://www.sau.com.au/forums/topic/424799-head-gasket/#findComment-6848636
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
