Hi,
I purchased my skyline 1 week ago and it was sitting in a garage for 18 months and had not been used...
Anyway I been driving it for just over a week and I started to notice the performance deterioate like a coil pack had just gone..
Turns out cylinder 4 is not firing so it sounds like a WRX and has no power at all...
I changed the coil plug and the spark plug and tested the lead...
So I think it has to be a clogged injector.. Does anyone know how to take the injectors out of a r32 ?
I have ran 1/2 a tank of optimax through it should I keep running it and hope the fuel will clean it ???? Please help!
Thanks, Scott
https://www.sau.com.au/forums/topic/42483-please-help/
Remove the crossover pipe to the throttle body, and there are 3 bolts that hold the rail in position on the side of the head.
The rail basically comes out the front, so disconnect anything that is blocking that (you'll see as you do it).
https://www.sau.com.au/forums/topic/42483-please-help/#findComment-868095
