Apexi PowerFC normal version (not djetro). But you would need to get it tuned by someone that knows them.
The Apexi Commander is just the hand controller for the Apexi PowerFC ECU.
The djetro version deletes the air flow meters and uses a thing called a MAP (manifold absolute pressure) sensor instead.
They will work with most other aftermarket ECU's as well.
If you have a PFC, you set it to the type of AFM's you are using - the Nismo's use the Z32 / VG30DETT (300zx) setting as they essentially use the guts of a Z32 AFM, in the body of an RB26 AFM.
Nistune or PowerFC being better / worse, there is no right answer. It really comes down to how well the car is tuned - so you want to go with a reputable tuner, tuning the ECU they are most comfortable with.
  • 5 months later...
