You guys should all be teaming up with the Grunt Files crew, they have started a good thing to try combat this sort of crap! Get on Facebook and like their page and you will see links to what they are up too! Like he said too me, United we stand....Divided we fall! As corny as that sounds it is true! One guy standing up against a fine goes unheard, 1000 guys standing up against a fine gets a hell of a lot more attention!
  • Replies 69
Pretty interested in this I just went to their Facebook and looks alright..
Maybe it is time for change :)
What harm is there in trying? If they succeed then awesome! If they dont, well at least they tried! :yes:
How about a $40 car cover?
They cant see sht then, they cant see rego or number plate.
Just cover your defects and rego when parking.
And some kind of alarm so they cant f&@k with it.
Or tiny locks so it cant be moved without breaking something, and if they do that....... well, you can imagine.
Hahahahahahhahahahaaaaaaa could imagine what kind of WANKER you'd look like rocking up to Woden and pulling out a car cover and putting it on :laugh: Especially since it's all undercover :laugh:
If you covered your car it kinda means you have something to hide; and not necessarily hiding from the RTA but more so from thieves who target car parks - they'll be thinking they've found a gold mine haha.
Thats true, hahaha! dint think about that.
:woot:
Pulling out a cover in any carpark would be fairly wanky.
I think in an undercover park, people will think your deranged.
:rofl2:
Believe me, they already think that from the moment they spot me.
This is crazy...
Like cracking down on it is fine - understandable. But do it to the future of cars that are coming through - not the ones that you (RTA) passed in the first place. If they're not confident in their mechanics to supply legitimate certs then punish them.
Its not that. Its because ACT doesn't have annual roadworthy certs. Cars can be 100% changed without letting anyone know. thats why they do it.
Correct, but they do it because they're revenue raising dream boats and it's EOFY lol
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
