500HP? If you say so. Sure, I'll take that.
No no no no no...........I want the information to be as accurate as possible on SAU so please enlighten to me how much poawha you had on that day ;)
This. Power figures for every run down to the tenth of a kilowatt.
big thanks to organizers, met a handful of other guys which is cool, and I will probably go to the next one. between now and then ill have to get back there to a few test and tunes to get the gremlins sorted. I got some footy also ill be uploading to Youtube soon from the day.
Also, thanks to a few guys who pulled up and offered assistance to me when my car started smoking after the 3rd, 4th, and 5th runs. I figured out why it was smoking... I was pushing that much oil up into the catch tank, it was going out the pcv and into the intake.
my fastest run was a 12.8 very early in the day (second run) when I was still learning how to drive it. unfortunately from there it just got slower and slower until I found I had lost 20mph at the big end.. later finding that I had 2 litres of oil in the catch tank, and about 1.5 liters had gone through the engine clogging up the air filter/intercooler/intake/AFM.. messy.. and a Big thanks! to Noel, for lending me tools to help me clean it up so I can drive home, your a champ mate.
cheers,
D
Hi Dale. I was one of the blokes to talk to you about your car. It was a pleasure to meet you. Hope to see you around at more SAU events soon and maybe with my car too ;)
Thanks mate, time is a killer for me and I'm on call 24/7 which makes it difficult. Definitely keen on attending more driving events, and I hope to see your beast their too.
cheers, D
Well now. Since you attended an official SAU event that automatically gives you an extra 50hp so no need to make any amendments :P
Well, I've been doing that for years, so god knows what I'm making these days!
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
