Hi all,
Can someone offer an explanation for this.
I ordered a magnetic sump plug for my GTR and was told all sump plugs for skyline R33 are same
M12 x 1.25
When I went to replace it the original was much larger (maybe M20) but I didn't compare the thread size
The possibilities are that it was bored out and tapped to a bigger size,
OR that they have told me the wrong size
Can anyone confirm what the case would be
https://www.sau.com.au/forums/topic/424882-r33-gtr-vspec-sump-plug/
I've bought a few of these, fitted them to the GTSt, Aristo, Patrol in fact anything with a tin sump.
The thread is M12x1.25 and is not the GTR size, which is why I still have this one in the shed.
Not going to drop my oil just to prove a point but from memory the alloy sump thread is around M16.
Thank you for your replies
I have done some more research and am very confused now
Some people are reporting same problem as me, some are not
Can anyone definitively say a vspec r33 is supposed to have an M12 x 1.25
I suppose my next step is to wait for next oil change and measure the plug
    • Only thing I'd add...is on recommendation from a good diff shop, I've used mineral oil in my diff including the race car for years. The synthetics can be too slippery and glaze the gears
    • 75W90 GL5 is fine. If you aren't sure about the type get one with LSD additive.
    • Because you're effectively rushing the shift and forcing it to go in - with greater leverage against parts that don't _want_ to go together. Short shift = forcing the gear in harder. Also Redline Heavy Shockproof actively says not to use it in anything with Synchros. Well, it says "not recommended" which is basically as far as anyone will ever say in a product statement to "Do not use" Generally the Redline makes the gearbox feel great... until it fails faster. https://www.redlineoil.com/heavy-shockproof
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
