Hi guys,
I bought myself a deep corn Nardi wheel a while ago and was talking to my mechanic as I never had a chance to install it (was waiting for a boss kit that never arrived). He told me that because my car is fitted with an airbag it would render the car defectable to replace the OEM wheel with the aftermarket one.
My question to anybody who may have gone through this is, is there a legal way that I can use my Nardi wheel??
Thanks in advance!
https://www.sau.com.au/forums/topic/424894-how-to-fit-a-nardi-wheel-legally/
An idea I was running through my mind was to buy the boss kit with 2 quick switch adapter kits, I could switch to my Nardi wheel when going on cruise days ect and switch back to the OEM wheel when using my car for daily use. I understand the rules and such but would this idea be able to bend the rules a little?
As above, doesn't matter if you can switch it back to the stock wheel or not, if you're driving with the nardi on it's illegal. And as far as I'm aware, no such quick release hub exists. Either stick with stock steering wheel with airbag and have it legal, or swap to a nardi with an after market boss kit and the first time you get pulled over, expect to be pulled up on it. No way around swapping out a stock wheel with airbag.
yep, all been said. it's illegal to run a non airbag wheel in your car. there are other possible legality issues with running the nardi wheel as well. not sure what the rules are in other states, but in QLD the minimum legal diameter of a steering wheel is 350mm. but there is a secondary rule that must be met. the diameter of a replacement steering wheel cannot be more than 25mm smaller than the standard wheel. so this means that if your car originally had a steering wheel that was 400mm in diameter, you can only legally put one in that is 375mm (25mm smaller). but if you car had a standard wheel that was 360mm, you could only go 10mm smaller down to 350mm.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
