Hi Guys,
I am having an issue with my nissan skyline r33 gtst.
I went to track days few times now and I get loss of power after first 5 laps. Power decreases significantly. At wakefield I can reach 175km/h on straight but after about 5 laps I can reach only 150.
So thats 10-20% power loss.
I assume this is because car is getting too hot.
Mods r34 intercooler, 3'' exhaust turbo back, boost controller 10psi. fuel pump.
-So far I have changed to use different oil from motul 8100xcess (10-40) to castrol edge 10-60.
-I flushed the radiator and put better coolant. I have not flushed the coolant in engine, the damn release screw is ridiculous to get to and unscrew.
-changed AFM, and fuel pump. so def not those and oh boy it drinks alot.
Any recommendations??
i bought the car of friend and he had the coils replaced few yrs back, i have his reciept.
well it has bigger intercooler, but i didnt want get front mount and restrict the radiator.
i suppose i should turn boost down and see if i still get the problem.
dont worry about restricting the radiator.... you have no where near enough power to do that.
my theory is after a few laps of full throttle you ic is getting warm. maybe try a front mount.
depending on the coils he put in they could also be breaking down due to heat.... remove cover if you can to increase air flow.
also if you have apod filter put standard air box back in. same thing happens as with small ic, filter starts sucking in hot air from engine bay and you lose power.
hey, thanks for advice.
i will lower boost to stock boost 6psi for next trackday, to see if it helps. That should show if intercooler is problem.
I removed cover for coils already.
the pod filter is just behind the light so that should get enough cold air in.
Do you think the old coolant in the engine could be the issue?
nah mate wont be coolant. unless engine is overheating...
that pod filter will not work.... unless you remove the light....
It would most definitely be the little side mount cooler as Paul causing your loss of power.
I remember my XR6 Turbo had the same issue with heat soak and the standard cooler.
As soon as I put a big front mount on it, problem solved.
Lowering the boost will help but then you'll just have that same constant low power.
this.
honestly. buy a standard airbox. alot of guys with nearly 300kw still run them. search if you dont believe me...
Or like mentioned before, remove headlight (easy enough to do in a couple of minutes at a track, a couple of plugs and some nuts), and put a headlight replacement air intake in place (just jap have them) and box off your pod filter. Induction cant get much colder than that.
+1 for heat soak. The 34 cooler might be an ok upgrade for on the street, but they are rubbish for the track. Put it on a dyno and after a few runs power will start to drop substantially. That is where a fmic is an upgrade. It doesn't give you any more power, but it increases how long you have power.
  • 1 month later...
hey guys,
i found what the problem was, too high boost, through my intercooler
i went to trackday on friday @wakefield park , and i lowered the boost from 11psi to 6psi, and this solved the problem. I did 10 laps straight and had no issues with loss of power.
most of time now i do 5 laps, then 1 slow lap, then repeat.
i think r33 has dual stage boost, as it goes up 6psi, but after 4-5krpm it goes up to 10psi, but i didnt have any issues.
anyways thanks for help, and do try wakefield park on weekdays, it was open track all day not many cars at all. :)
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
