Hi Guys,
I am having an issue with my nissan skyline r33 gtst.
I went to track days few times now and I get loss of power after first 5 laps. Power decreases significantly. At wakefield I can reach 175km/h on straight but after about 5 laps I can reach only 150.
So thats 10-20% power loss.
I assume this is because car is getting too hot.
Mods r34 intercooler, 3'' exhaust turbo back, boost controller 10psi. fuel pump.
-So far I have changed to use different oil from motul 8100xcess (10-40) to castrol edge 10-60.
-I flushed the radiator and put better coolant. I have not flushed the coolant in engine, the damn release screw is ridiculous to get to and unscrew.
-changed AFM, and fuel pump. so def not those and oh boy it drinks alot.
Any recommendations??
i bought the car of friend and he had the coils replaced few yrs back, i have his reciept.
well it has bigger intercooler, but i didnt want get front mount and restrict the radiator.
i suppose i should turn boost down and see if i still get the problem.
dont worry about restricting the radiator.... you have no where near enough power to do that.
my theory is after a few laps of full throttle you ic is getting warm. maybe try a front mount.
depending on the coils he put in they could also be breaking down due to heat.... remove cover if you can to increase air flow.
also if you have apod filter put standard air box back in. same thing happens as with small ic, filter starts sucking in hot air from engine bay and you lose power.
hey, thanks for advice.
i will lower boost to stock boost 6psi for next trackday, to see if it helps. That should show if intercooler is problem.
I removed cover for coils already.
the pod filter is just behind the light so that should get enough cold air in.
Do you think the old coolant in the engine could be the issue?
nah mate wont be coolant. unless engine is overheating...
that pod filter will not work.... unless you remove the light....
It would most definitely be the little side mount cooler as Paul causing your loss of power.
I remember my XR6 Turbo had the same issue with heat soak and the standard cooler.
As soon as I put a big front mount on it, problem solved.
Lowering the boost will help but then you'll just have that same constant low power.
this.
honestly. buy a standard airbox. alot of guys with nearly 300kw still run them. search if you dont believe me...
Or like mentioned before, remove headlight (easy enough to do in a couple of minutes at a track, a couple of plugs and some nuts), and put a headlight replacement air intake in place (just jap have them) and box off your pod filter. Induction cant get much colder than that.
+1 for heat soak. The 34 cooler might be an ok upgrade for on the street, but they are rubbish for the track. Put it on a dyno and after a few runs power will start to drop substantially. That is where a fmic is an upgrade. It doesn't give you any more power, but it increases how long you have power.
  • 1 month later...
hey guys,
i found what the problem was, too high boost, through my intercooler
i went to trackday on friday @wakefield park , and i lowered the boost from 11psi to 6psi, and this solved the problem. I did 10 laps straight and had no issues with loss of power.
most of time now i do 5 laps, then 1 slow lap, then repeat.
i think r33 has dual stage boost, as it goes up 6psi, but after 4-5krpm it goes up to 10psi, but i didnt have any issues.
anyways thanks for help, and do try wakefield park on weekdays, it was open track all day not many cars at all. :)
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
