I think it was 6 months from first contact to delivery and we were quoted for a complete time from fabrication to delivery of 2.5 weeks. It was enough that I felt bad that you spent so long on the phone you got a bottle of Jack (or Beam I can't ever remember now haha) for your efforts :)
Quality product, absolutely f**king disgraceful customer service.
Yeah that sounds about right.
I remember the bottle of booze, went down a treat lol
Should be pointed out to others, it wasn't 6mths of waiting it was 6mths if actively chasing him and unraveling a web of lies etc etc, there's details over in the ProFab thread, there are still people waiting for items YEARS after paying.
AGI can do all welded too :)
Of course they can, but not for $700 delivered and still using 44mm CDS. AGI's Bolt in/Bolt together cage was more expensive than that.
I have no issues with AGI and I'm not saying ProFab does anything better, I'm only pointing out that the value for money was exceptional in what we bought.
If I had to do it again though, knowing what I know, I'd save myself 6mths and spend an extra few bucks and go local or AGI.
Read the thread, sorry you had such a s#it time getting your cage.
Just a small note, While ROPS is very important, one big thing you may want to think about is, side impact. This is far more likely than going over on your lid.
Also if you are going to be running a harness, maybe think about a HANs. I was stupid enough to go out, without one on.
18 months later, my neck is still not right, and I ended up having 5k worth of eye surgery.
Edited by toppertee
  • 3 weeks later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
