Hey guys,
Planning an R33 gts-t build atm and am looking for some efficient bov solutions.
Alot of people praise the stock GTR twin BoVs for their performance.
I was wondering whether people run just a single GTR bov or use the twins on other engines (more so rb25dets).
Also, I was wondering if anyone had a sound clip of them. I searched all over youtube but the only videos I got are off gtr's running loud aftermarket bov's. People say they sound good and subtle, so has anyone got some audio. Perhaps a generous GTR owner could take a sound clip?
Any info would be great
Cheers
I dont mind the quieter bovs out there, but some are stupidly loud. GTR stock twins from what people say sound good but yeah if you or anyone can get some audio that would be mad.
On the other note, if anyone has ran them on an RB25DET did you run both or just one? I am planning on a basic stock internal rb25det / gt3076r / usual supporting mods to get to around 300rwkw.
Just keep in mind that aftermarket plenum wont pass a mechanical inspection, mine didn't and they are a nightmare to change over
And all aftermarket bovs do is attract attantion and get defected and better yet u save cash!
Edited by discoPumpkin
Hah. Plenum change to "neaten" then engine bay. The definition of a worthwhile modification.
It does make for less intercooler piping and instead of running piping across the rocker cover
But still expensive to do just for street car. I was reading that the r34 neo plenum was the reason it gave that motor much more bottom end torque over 33 rb25, so if he got one of them from a wrecker would be cheaper.
I also read that cheap plenums of ebay can cause the motor to seize, so just be careful
Amy more info on the causing motors to seize? :)
  • 4 months later...
Hi guys,
Rather than start a thread on the same topic, I have searched and this is close as I found, i too have an RB25DET and a pair of GTR BOV's which are yet to be installed. I was hoping someone could post a pic of how they were mounted using a forward facing inlet manifold and plumbed back in to the intake pipe. The reason I bought them and want to use them is that the current bov works well when venting to atmo but doesnt seem to work when plumbed back. I just get a lot of flutter back through the turbo. The pipe that the current bov is mounted on will be eliminated, non standard pipe anyway, when the inlet manifold is installed.
Thanks in advance.
Liam
Well, given that the BOVs are installed in the intercooler cold pipe just in front of the driver's side front wheel....that should pretty much tell you where it makes sense to install them on a GTST with a FFP.
I don't know if I would use both though. If you install both, you then have to joint their outlets back up in order to take just one hose over to the inlet side, or you end up having to take 2 hoses over to the inlet side. There's plenty of high power RB25s running just one of these.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
