So I've just purchased a stagea, one of the issues was the fuel gauge showed full all the time, but the fuel low light would still work
what u need
Philips screw drivers
2 bench powersupplys or a powersupply with 2 adjustable outputs
I removed the steering coloum covers 4 screws
Removed the dash cluster cover 2 Screws up the top
poped the rear windows spray and the demister buttons and undid plugs
removed the dash cluster
removed the front plastic overs
and then removed the fuel gauge
I hooked it up to a powersupply on the bench to check that it worked
there is a ground and to signal wires
I put 12 volts to first single gauge went one way and put 12 volts on the other signal and went the other, so I new my gauge was working!
The gauge works from the difference of the 2 signals , if both signals has 12 volts the gauge should read in the middle or 1/2 tank, this was my first problem, as the gauge when having 12 either side of it was still reading over full
We moved the needle down till when we put 12 volts both side it sat at half a tank, so this has calibrated the gauge on the bench so it's sitting in the correct location.then changing the difference between the volts the gauge then started going up and down! I also kepted the voltage very low and bumped a bit of current up, this would also give the copper a good buzz in case of corrosion etc
put the gauge back, and is working well!
Edited by poohkies
  • 4 months later...
Hey guys,
do we know what the ohms of the gauge are? e.g 0 ohms when empty- 90 ohms when full. Want to make a custom dash and replace all gauges but there are a few different options for what the gauges read as empty. Any advice?
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
