G'day everyone,
I've been up ALL night long mind f**king myself as to HOW TO INSTALL an OIL CATCH CAN.
I understand that it's a relatively simple job, just time consuming at best. HOWEVER, I am absolutely and entirely LOST as to what happens with the Air intake part of things (does the catch can need its own air filter) and even as to whether I'm going to HAVE TO modify somewhere along my air intake to allow a clean flowing air or "vacuum" as many people have mentioned. WHICH THEN leads to me wondering will my Air intake sensor be stuffed up if I cut holes or put filters in my Air box.
As you can see, I am totally MUDDLED and have spent the last 4 hours searching and searching for a STEP BY STEP process for installing a Catch can in a N/A RB30 Sedan...
If anyone could make simple
  • step
  • by
  • step
Instructions, from begging to start and explain to me as to whether I even NEED to put an air filter/air vacuum for a catch can to work?
Pictures and VERY simple instructions/terms if at all possible would mean the absolute WORLD.
Thanks a million!
https://www.sau.com.au/forums/topic/425078-installing-r31-na-rb30-catch-can/
Just take off existing breather pipe that goes from rocker to plenum, and add catch can inbetween. simples.
Or better yet, dont worry about it and sell it.
Edited by superben
  • Like 1
So everything I'm reading in relation to the air intake / pvc sensor etc, is to mainly do with Turbo'd vehicles, and doesn't apply to me?
Just as simple and straight forward as in this video which I've just stumbled on?:
He talks about air intake as well and that "You'll know what to do when you get to that part", WHAT if anything do I need to do in regards to the intake/''that part'' of the installation etc?
Or is it purely as he states; just so he can access what he's doing more easily?
Dude, it is so easy.... One end of can attaced to rocker cover , other to plenum. this photo shows the hose that is replaced, the catch can hoses go here. when you take that hose off, attach the catch can hoses to the two spots. that is where the blowby that might have oil mist in it gets sucked into the engine, so that is where the catch can has to go to catch it! If you are still confused, I can't help you !post-107339-0-39394500-1368360071_thumb.jpg
Cheers a million guys, you've made it really as simple as it should've been from the word "go".
Obviously it was due to Turbo'd vehicles/installs I was reading and getting confused, as there seems to be just a little more work involved when installing a catch can on a Turbo apposed to a N/A / Standard RB30.
Just to completely clarify, I've circled what I have to remove and place the catch can 'in line' between these two fittings and instead use the catch cans braided hoses.
The circled hoses are the ones I'll be removing when installing the catch can, Yes?
IF this is NOT correct, can someone PLEASE circle and upload on the same image what I have to remove?
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
